Tom's Hardware Forums » Motherboards & Memory » Tyan » Thunder HEsl S2567 ACPI problem
Word :   Username :
Bottom
Author
 Thread : Thunder HEsl S2567 ACPI problem
More Information
Archived from groups: alt.comp.periphs.mainboard.tyan (More info?)
I'm trying to install Windows XP Pro on a Tyan Thunder S2567 dual-P3 board
using the Serverworks HE-SL chipset and I cant get ACPI to work.
When I install XP with ACPI on and Plug-n-Play-OS on I cant get the
integrated serial, parallel and Ethernet interfaces to work. I get loads of
resource conflicts between them and even with manual resource assignments in
the device manager I dont get them all to work.
I contacted Tyan support and their answer was: "The Serverworks Chipset does
not like ACPI. Disable the ACPI in the bios and attempt to install your
system again."
Is that Chipset / BIOS really that buggy ??
I did upgrade to the latest BIOS 1.05a, which is from 2001 so it isnt very
likely that Tyan will release a new one.
Unfortunately when I install XP with ACPI turned off I loose the
functionality that after shutdown it also powers off.
Any workaround for that ?
thanks
any help appreciated
Google Ads
News
ATI Catalyst drivers have a problem
Published on August 27, 2004
ATI has a problem in the latest Catalyst drivers. Read more
Nforce 3 to come in PCI Express flavour
Published on March 26, 2004
Nvidia is putting its Nforce 3 chipset on the PCI Express. Read more
Tyan unveils nForce Pro mobos
Published on January 25, 2005
Tyan today launched a pair of motherboards based on Nvidia's recently announced PCI Express-based nForce Pro 2200 and 2050 chipsets, both geared to workstation and server systems based on AMD's 64-bit processors. Read more
Nvidia Contract Makers In Taiwan Low-key Over Defective Chip Reports
Published on July 07, 2008
Nvidia's Taiwan-based graphics chip contract makers are being low-key after the US chip designer informed investors on July 3 that will take a charge of US$150-$200 million related to expenses stemming from issues discovered with die/packaging materials used in previous generation notebook products. Read more
Latest Reviews & Articles
Atom, Athlon, or Nano? Energy-Savers Compared
Published on October 03, 2008
We compared Intel’s Atom 230 and VIA’s Nano L2100 processors hoping to find the best product for low-power applications. VIA is in the vanguard of performance. Is this enough to beat Atom? Read more
Interview: Bigfoot's Killer NIC, Exposed
Published on October 02, 2008
Since its release, the Killer NIC has garnered a reputation for being an extravagant and largely unnecessary add-on for the do-it-yourselfer. Seeking additional insight, we approached the card's designer. Read more
Seagate's 1.5TB Barracuda: Bigger And Better?
Seagate is the first hard drive vendor to offer a 1.5 TB drive in the 3.5” form factor. Meanwhile, WD sent us its RAID Edition 3 (RE3) drive. We tell you which is the best HDD choice today. Read more
Updated CPU Charts 2008: AMD Versus Intel
Published on October 01, 2008
The processor is the heart of your PC, and our updated charts for Q3 2008 show 54 of them competing in terms of performance. Using our updated suite of benchmarks, compare your favorite AMD and Intel CPUs after reading this introduction. Read more
