Belkin UPS battery problems
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
I have a Belkin F6H500-USB UPS. Connected devices are a AMD 1700+
computer, a 19' monitor, a cable modem, and a switch/router. The UPS
charge was between 90-96% when the unit switched to the battery power.
However, there was one power problems in the rest of the house. This
event occured again after about a hour. I unplugged everything and let
the unit fully charged over night. I turned it on to check the battery
level before adding the devices. It displayed 100%. Being cautious, I
turned it off and let it charge for another 4-5 hours. Turned it back
on and the battery charge fell to 93%. Bad battery? Also, what would
make unit switch from AC to the battery without any power problems from
the wall outlet?
7 answers Last reply
More about belkin battery problems
  1. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    I just had another event. The UPS battery was sitting at 87% after I
    performed a test. 30 minutes passed and then boom. The UPS switched
    over to battery. Nothing plugged into the UPS either. I guess thia
    points to some internal problem with the unit.
  2. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    OK. UPS batteries are typically of the lead-acid type and
    it means that start deteriorating right out of the factory
    (or when the acid is added). This behavior is about right
    for an old battery. Change the battery.
  3. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    In news:OnPW$E4bFHA.1404@TK2MSFTNGP09.phx.gbl,
    Ghostrider <-00-@fitron.142> had this to say:
    My reply is at the bottom of your sent message:
    If the battery is fine and Belkin supports this then check the sensitivity
    settings through it's GUI. It might be needing to be set to medium perhaps?
    (Only three options on the APC hooked up at the moment and I've never used a
    Belkin.)
    Galen
    "And that recommendation, with the exaggerated estimate of my ability
    with which he prefaced it, was, if you will believe me, Watson, the
    very first thing which ever made me feel that a profession might be
    made out of what had up to that time been the merest hobby."
    Sherlock Holmes
  4. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Nothing is making sense now. I took the UPS into a different room (my
    family room) and plugged it in to charge. It was off while charging
    for about 10-11 hours. I installed the monitor software and it shows a
    100% battery level charge. I ran the 10 second test which passed.
    Turned it off again for about another 2-3 hours. Then turned it back
    on to see if there were any changes (because the times before the
    battery level would drop or fluctuate between 85-95%). This time the
    battery level still maintained its 100% charge. This morning the
    battery level is still at 100%. This after another 6 hours of being
    turned off and plugged in to the AC.
    Maybe something is happening in my office that is making the UPS switch
    over to battery but for the life of me I don't know what it is.
    Everything else in the house is fine. The UPS is only acting strange
    in my office.
  5. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    No meters to speak of. However, since having these problems with the
    Belkin F6H500. I purchased a Belkin F6B750-AVR. The AVR (Automatic
    Voltage Regulation) feature has exposed some issues within my office.
    I was able to determine that when my air conditioning unit fires up the
    new UPS's AVR feature would kick in. Which indicated that the UPS was
    "cleaning" the current running through the UPS connections. So I now
    know the source of the current issues in my office (and home), the AC.
    I now agree with everyone else that the battery on the F6H500 is shot.
    I had stated the battery was holding a 100%. But it dropped again down
    to 87% without anything being plugged into it. So I'm just using it as
    a surge protector now. Thanks to all for their input.
  6. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    In news:1118673595.260036.63580@g14g2000cwa.googlegroups.com,
    d28 <kevindu28@yahoo.com> had this to say:
    > a 100% battery level charge. I ran the 10 second test which passed.
    > switch over to battery but for the life of me I don't know what it is.
    > in my office.
    Do you have a voltage/multimeter? If so set it to read volts (AC of course)
    and stick it into the socket in question. Leave it there for a while and
    look at it on occassion. Is it fluxuating? More than a few volts? If it's
    only a few volts try the sensitivity that I mentioned in the last response.
    If it's more than 5 either way I'd consider a call to a licensed
    professional to have the problem looked into. (Note that not all outlets
    will read 110 volts. I just ran a short test on one of the older outlets in
    a shed - long story - and it ran from 114 to 117 so I'll figure that's
    normal for most people.)
    Galen
    Sherlock Holmes
  7. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    You are making assumptions without even having sufficient
    experience. To appreciate why the numbers from the first UPS
    could be 100% normal operation, you should get a 3.5 digit
    multimeter and do some voltage testing on your car battery.
    What is the voltage when charging? What is the voltage after
    car is turned off? What it the voltage after sitting
    overnight? What is the voltage when hi beams are turned on?
    If you can answer these questions from previous experience,
    then your UPS reading make complete sense. But since you do
    not have experience and do not have the 3.5 digit meter to
    gain that experience, then you are only speculating.
    Same is speculation about the UPS 'cleaning' your office
    electricity. That's nonsense. The air conditioner may be
    connected to a circuit wires sufficient for incandescent lamps
    but not wires sufficient for electronic equipment.
    Follow the wires from wall receptacles back to breaker box.
    Did they connect each wire solidly to screw on side of
    receptacle? Or did they connect wires in holes behind that
    receptacle? If not using the screws, then you have identified
    a wiring problem. The resulting low voltage was tripping that
    UPS into battery backup mode.
    BTW, when does the computer typically see the most 'dirty'
    electricity? When UPS is in battery backup mode. Computer
    grade UPSes output electricity so dirty as to harm some small
    electric motors. And yet that same 'dirty' electricity is
    perfectly good for electronic appliances - that have more
    resilient hardware.
    If you want to learn from your experiences, then you get a
    3.5 digit multimeter that is a tool as important as a
    screwdriver; so ubiquitous as to be sold in Walmart, Home
    Depot, Radio Shack, and Lowes. Also time to inspect each wall
    receptacle between breaker box and office. Again, to learn
    WHY these things are occurring.
    As for those readings, well, what is does the manufacturer
    spec for that UPS state is resolution? IOW 87% and 100% are
    same readings for a battery at 96%. Numbers that might change
    based upon other external factors such as room temperature and
    receptacle voltages. No way around the need for that meter if
    you want to answer your questions. No way around the need for
    those numbers.
    You have no way of guessing (with any integrity) about that
    battery unless you take numbers with the multimeter (and
    report those numbers here to learn other facts not yet
    provided).
Battery Belkin Windows XP
