I am having some issues with some of my games in MAME32.
Games such as Dig Dug, Qix, Rally X, Burgertime, and PacMan fire up and
play fine.
A lot of the games however have very choppy gameplay and poor screen
rates. Tempest, Mappy, Paperboy, Pole Position are extremely bad.
On a somewhat related note Mappy USED to play fine and I had an older
version. Then one day Mappy started acting up. I though updating
would help but apparently it hasn't.
Any help you can provide would be greatly appreciated.
> play fine.
As MAME gets bigger, the performance goes down. Older versions of MAME
(.57 or so) will run most games on a 500 MHz processor. I have .95
installed now and it won't even run Don Den Lover Vol. 1 at full speed
on my Athlon XP 1700. Version .86 runs it just fine.
Remember, the purpose of MAME is accurate emulation/preservation of the
game code. Actually PLAYING the games is just a side effect of that effort.
I suggest you use the oldest version of MAME that will play the games
you want.
>> play fine.
> effort.
> you want.
> HTH, HAND
......and to easily find out the oldest version, take a look at the
second half of 'catver.ini', which can be found at http://www.catver.com/
