Tom's Hardware > Forum > Wireless Networking > Wireless General Discussions > XP SP2 not connecting to wireless
Archived from groups: microsoft.public.windows.networking.wireless (More info?)
I have just bought a laptop with SP2 pre-loaded. I also have an origo
wireless modem/router which is set to 64bit encryption with a shared key not
an open system.
If I try to connect the laptop to my network is says that it can find a
wireless network that is security encoded but will not allow me to enter the
system despite me entering the correct access key. It refuses to obtain a
network address, despite the laptop working (after using WinXPIPfix to
correct the continual problem will windows on its IP configuration - it
always defaults to 169.x.x.x instead of using DHCP to reset the address to
10.x.x.x - This is a microsoft problem that they refuse to fix) when
connected by a cable.
What setting need to be altered to gain access to the wireless network? The
router uses WEP I believe (yes I know it is old and crackable but each of my
machines has its own firewall to stop access between machines on the network
- no files are shared only printers and DVD drives), and it does not have an
upgrade for WPA.
Sponsored Links
There are 824 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
