IEEE 1394b Device Detection Issue XP SP2
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
has any one run into IEEE 1394b device detection problems?
The Problem
Windows XP Service pack 2 fails to detect multiple IEEE 1394b devices
properly.
When multiple IEEE 1394 devices (DVD Recorders) are first attached to a
Windows based system device manager detects them but initially one of them
has a yellow mark on it which over a period of time (roughly 2-3 minutes)
propagates to all 4 of the newly attached devices. The devices will work If
you cycle the power on them after all 4 devices have a yellow mark on them.
If you don't wait until all for devices have a yellow mark on them before the
power is cycled the devices will not be properly detected even after a power
reset or reboot. Once the recorders are detected properly the system seems to
function without any problems, unless you swap out the IEEE 1394 host adapter
or DVD recorder.
The following message is being logged into the system event log; Event ID 4
source "Sbp2port" Description "Driver detected an internal error in its data
structure"
Any Ideas
Snazzzz
6 answers Last reply
More about ieee 1394b device detection issue
  1. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    > The Problem
    > properly.
    > them
    > minutes)
    > work If
    > them.
    > before the
    > power
    > seems to
    > adapter
    > or DVD recorder.
    > ID 4
    > data
    > structure"
    > Any Ideas
    > Snazzzz
    In a hardware configuration where multiple 1394 buses are joined (also
    known as bridged), Microsoft does not guarantee that 1394 devices
    attached to either side of the bridge will behave the same as devices
    attached on the local 1394 bus. This feature is under review and will
    be considered for inclusion in a future release.
    I truly can't say this is your problem or that it completely applies to
    you, but it was the closest find. (If) this is the cause then at least
    it might not be your pc.
    PCDaddyPosted from http://www.pcreview.co.uk/ newsgroup access
  2. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    The devices are bridged, I’ll try to connect each recorder individually and
    see what happens. I’ll post the results.
    Thanks for the information
    Is this information on Microsoft’s web site?
    Snazzzz
    > > The Problem
    > > properly.
    > > them
    > > minutes)
    > > work If
    > > them.
    > > before the
    > > power
    > > seems to
    > > adapter
    > > or DVD recorder.
    > > ID 4
    > > data
    > > structure"
    > > Any Ideas
    > > Snazzzz
  3. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    STATUS
    Microsoft has confirmed that this is a problem in the Microsoft
    products that are listed at the beginning of this article. This problem
    was first corrected in Microsoft Windows 2000 Service Pack 3 (SP3) and
    Microsoft Windows XP Service Pack 1 (SP1). and screwed up in (SP2)
    'KB311430' (http://support.microsoft.com/?kbid=311430)
    You can revert back to SP1 drivers for certain devices. How
    Sbp2port.sys was changed to non-functional in SP2, is a mystery to me.
    Best,
    Treeman
    Treeman
    Treeman's Profile: http://www.msusenet.com/member.php?userid=1260
    View this thread: http://www.msusenet.com/t-1870536845
  4. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Do you know if Microsoft has confirmed that this is an Issue in SP2? This KB
    article isn’t clear on whether this is a problem in SP2.
    Treeman, have you run into this problem?
    FYI,
    I opened a case with Microsoft 5 weeks ago they keep telling me that they
    are researching the issue, all talk very little action.
    I tried connecting each device to a separate host adapter, still having the
    same problem.
    Thanks
    -- Snazzzz
    "Treeman" wrote:
    > STATUS
    > Best,
    > Treeman
    > Treeman
  5. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    > individually and
    > Snazzzz
    > > > The Problem
    > devices
    > > > properly.
    > to a
    > of
    > > > them
    > > > minutes)
    > > > work If
    > on
    > > > them.
    > > > before the
    > after a
    > > > power
    > system
    > > > seems to
    > host
    > > > adapter
    > > > or DVD recorder.
    > Event
    > > > ID 4
    > its
    > > > data
    > > > structure"
    > > > Any Ideas
    > > > Snazzzz
    > (also
    > to
    > least
    Yes the info is on MS. I copied and pasted it directly.
    http://tinyurl.com/cuaks
    Here is the link. Good luck.
  6. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    I was told that they are looking into the issue also. A hotfix may be in
    the future.
    "I opened a case with Microsoft 5 weeks ago."
    It's a long way from Redmond to India!
    Best,
    Treeman
    Treeman
Detection Devices Windows XP
