Archived from groups: microsoft.public.windowsxp.hardware (
More info?)
What shows up in Disk Management (Right click on My Computer, select Manage,
on the following screen, click on Disk Management... they will show up on
the right hand side of the screen).
Cari (MS-MVP)
Printing & Imaging
"Walter Wu" <walterwu@mymail.com> wrote in message
news:d986hc$lgi$1@nobel.pacific.net.sg...
> "USB2 Enhanced" is what is shown on the Device Manager.
> "Cari (MS-MVP)" <Newsgroups1@coribright.com> wrote in message
> news:eG7IqRUdFHA.2212@TK2MSFTNGP14.phx.gbl...
>> And they are listed as "Enhanced" or USB 2.0?
>> Cari (MS-MVP)
>> Printing & Imaging
>> news:d95a21$qul$1@nobel.pacific.net.sg...
>>> Hi Cari,
>>> Forgot to mentioned that I have done that already. The system reports
>>> it the most current driver.
>>> Tried uninstall the USB Controller and the system detected the "new"
>>> hardware and re-installed the USB driver.
>>> Tried disabling the USB 2.0 on the Device Manager only to find that the
>>> USB keyboard and mouse no longer works and had to use a PS/2 mouse to
>>> login and re-enable the USB 2.0 controller.
>>> Thanks.
>>> Regards
>>> Walter Wu
>>> news:ujQihyTdFHA.2180@TK2MSFTNGP12.phx.gbl...
>>>> Go into Device Manager and scroll down to the UBS Controllers.... right
>>>> click and select Update Drivers.... then click on Update Drivers tab.
>>>> You want to ensure your USB ports are running the 2.0 drivers and
>>>> haven't somehow reverted to 1.1.
>>>> Cari (MS-MVP)
>>>> Printing & Imaging
>>>> news:d954e2$ned$1@nobel.pacific.net.sg...
>>>>>I had been using an iWill 5-in-1 usb 2.0 card reader for quite a while
>>>>>now.
>>>>> Lately, when I plug the card reader into the same usb slot, it doesn't
>>>>> work anymore. What happens, it says it is a USB 2.0 device and can
>>>>> support higher speed. Check the Drives lettering and only 1 drive is
>>>>> reported but not working.
>>>>> How do I test whether it is the usb port or card reader that is
>>>>> faulty?
>>>>> Regards
>>>>> Walter Wu
