G
Guest
Guest
Archived from groups: alt.comp.hardware.overclocking.amd,alt.comp.hardware.overclocking,alt.comp.mainboards.abit (More info?)
I have been having sporadic problems with my system rebooting for no
apparent reason as well as IE crashing (again for no apparent reason). I
have Win XP Pro on an ABIT KX-333 and it doesn't happen all the time,
perhaps once per week. I am trying to find the suspect memory.
I have two sticks of PC2700 DDR memory CAS-2 (256k each). One stick is from
Kingston and one is from Crucial). I don't do overclocking/tweaking.
I ran both memtest86 as well as Microsoft's memory testers and one of the
tests fails. Microsoft's test of STRIDE6 always fails. MEMTEST86's test 6
always fails (I assume these tests are the same across the software). I only
ran these tests for about half an hour.
My next step is to take one memory stick out and re-test, then swap the
memory and test again.
Any other ideas/suggestions for me on testing and identifying the 'bad'
stick?
Thanks,
Walter
stick?
Thanks,
Walter
