Archived from groups: microsoft.public.windows.networking.wireless (
More info?)
As Mark said, thats a good thought because it was a little touchy when
pressed into the PCI slot on my machine.
"Mark" <mjman2112@yahoo.com> wrote in message
news:Obl4K87QFHA.2356@TK2MSFTNGP14.phx.gbl...
>I had the same problem. Try a different PCI slot.
> "-+= graq =+-" <google@graq.co.uk> wrote in message
> news:549db26c.0504152328.505fb61d@posting.google.com...
>> Thanks Parker, but I have tried that many times.
>> I Disable Wired LAN (onboard). I uninstall WLAN card in device
>> manager.
>> Reboot the machine - WinXP detects the hardware, I opt not to connect
>> to the internet (especially as it is disabled).
>> The install wizard the prompts me 'to insert install disk' if there is
>> one.
>> I place the CD in the drive, there's a bit of a whirr and then the
>> install wizard tells me:
>> "The wizard could not find the software to install your component for
>> ... ? network controller".
>> I personally think that that is appaling.
>> "Parker" <nospam@nospam.com> wrote in message
>> news:<OBtHZ5cQFHA.2136@TK2MSFTNGP14.phx.gbl>...
>>> grag,
>>> I had the same problem when I tried to install that same card. What I
>>> did
>>> was uninstall the card in device manager, restarted the pc and allowed
>>> XP to
>>> find New Hardware. When prompted by XP I put my driver CD in for the
>>> card
>>> and finished the install. I also disabled my LAN card. Once I did all
>>> of
>>> that it still looked like it wasnt installed so I just tried to connect
>>> to
>>> my network and then it worked fine.
>>> news:549db26c.0504150204.513a7e6a@posting.google.com...
>>> >I am having enormous problems installing a WMP54-G card on WinXP.
>>> > I have all the latest drivers from linksys, but Windows refuses to
>>> > 'see' the drivers and install the card!? I have tried all sorts of
>>> > permutations and I'm just running out of ideas.
>>> > The card has been successfully installed ona win2k machine by a
>>> > friend.
