Archived from groups: microsoft.public.windows.networking.wireless (More info?)
This one has stumped me. I set up a client's network which worked fine
at my address but two days later has a puzzling problem. Consists of a
USRobotics 9106 wifi modem/router/switch, an XP desktop connected to the
switch with ethernet cable, and an XP Laptop connecting via a wifi adaptor.
Both can access the Internet. The laptop can access the desktop share
and ping it with no problem. But the desktop has BIG trouble pinging the
laptop. Sometimes pings get through with big delays but mostly they time
out. So we have a link that acts a bit like a diode - only works one way!
The desktop NIC has a static address (192.168.1.2) with proper subnet
mask and correct DNS entries.
Any bright ideas as to what I can do to track down the problem?
> TIA.
is the desktop firewall off ?
>> the switch with ethernet cable, and an XP Laptop connecting via a wifi
>> adaptor.
>> the laptop. Sometimes pings get through with big delays but mostly
>> they time out. So we have a link that acts a bit like a diode - only
>> works one way!
>> TIA.
No. I use ZA on both and both links worked fine when they left my place.
There is a trusted zone setup covering the LAN static IP address range.
