G
Guest
Guest
Archived from groups: alt.comp.hardware.overclocking.amd (More info?)
Hi all
I've got an old XP2000+ lying around which I actually pronounced dead some
time ago. To explain, I was attempting to put a tiny spot of thermal paste
on the CPU die - when I "sneezed & squeezed". The result was thermal gloop
all over the CPU. I tried to clean it off the best I could but the CPU was a
no go from them.
So I guess there's two questions I need to ask: -
1. Could I use white spirit/meths to clean the gunk off the CPU or do I need
a specialist cleaner?
2. How slim are the chances that after the gloop is removed that the CPU
will work as normal?
TIA
BillL
Hi all
no go from them.
TIA
BillL
