RAID 1 Problem in Win XP
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
Hi all,
I think I have made a big mistake on my RAID 1 implementation. Please can
someone advise:
I had a single 160gb maxtor HDD system that I converted from Basic to
Dynamic (for some reason;)) I then purchased an identical drive, and
connected it to my on board 2 ATA slot, went into the config, and created a
raid and copy mirror 1.
The source being my (dynamic) working drive, contents were copied to the
fresh unpartitioned identical drive. On completion, rebooted, now windows XP
will not boot. The system is constantley rebooting in a loop.
Is this beucase my source was dynamic? If so is there a quick fix so that I
can get my system back up?
FYI
I have tried to slave the disks in another machine, however cannot access
the drives, something in Disk Managmenet about foreign disk, and unable to
import the data. However I have used 3rd party software to recove the data,
what I really need is to fix the boot problem so that I dont have to rebuild.
Any advise would be great.
Darren
16 answers Last reply
More about raid problem
  1. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    In article <A847674E-3FF7-418F-B1BD-088DCAE6C5EF@microsoft.com>,
    Darren@discussions.microsoft.com says...
    > Hi all,
    > someone advise:
    > FYI
    Windows XP does not support RAID at the OS / Disk Manager layer - you
    have to have been using a third party tool of some sort.
    Dynamic disks are the only ones that can be mirrored - you can't RAID
    basic disks.
    spam999free@rrohio.com
    remove 999 in order to email me
  2. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Hi Leythos,
    Im using XP pro and I was under the impression that it does support software
    raid?
    Im not using any 3rd party software, only the RAID config from boot up that
    is bundled with the mothorboard startup.
    Are you saying it is not possible that this problem has occoured due to me
    convertin the primary disk to dynamic under XP before initiating the Hardware
    RAID 1?
    > > Hi all,
    > > someone advise:
    > > FYI
    > basic disks.
  3. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    In article <2792E76B-0AD2-4242-BB9D-370960AAEDF1@microsoft.com>,
    > Hi Leythos,
    > raid?
    > RAID 1?
    Dynamic disks are the way to go with XP/2003, they are a normal function
    and have nothing to do with a RAID issue.
    It now sounds as though you have hardware raid, not windows based RAID
    (or soft raid) and that you just didn't configure the hardware raid
    properly.
    What you should have done was setup the first physical drive, get it all
    working as you wanted, rebooted, added the second physical drive to the
    hardware raid telling the controller to mirror disk 0 to disk 1 and then
    wait for it to complete.
    It sounds like you didn't do something in the right order or you
    mirrored disk 1 to disk 0.
    One last thing - when doing a hardware RAID, the drives are not always
    (mostly not) able to be moved to any OTHER controller - not even to
    another box without the exact same controller.
  4. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    ah so what your saying is that you need to setup the raid via disk management
    on the primary disk first before installing the 2nd disk.
    If so how is this done, I thought I already did this, hence the disk is
    dynamic?
    Also is there a fix to get one of the disks to boot again?
    Thanks Leythos
    > > Hi Leythos,
    > > raid?
    > > RAID 1?
    > properly.
  5. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    In article <4AFDDA2A-3AF2-4667-A42B-265DA569D4A3@microsoft.com>,
    No, what I'm saying is that you are confusing RAID with XP and some
    vendors hardware/drivers.
    XP does not do RAID via Windows, it supports the installation of RAID
    controllers and RAID controller drivers, but XP does not do RAID like
    2000/2003 server does - meaning you can't click on the drive and select
    MIRROR from the Disk Management screen.
    So, what motherboard, what IDE/SATA/SCSI card are you using, what RAID
    controller are you using?
    > dynamic?
    Here is how I do it:
    1) Install Disk 0, partition, and setup OS and applications making sure
    to use the F6 option to load the RAID controllers drivers.
    2) Make disk dynamic
    3) reboot
    4) Install Disk 1, don't do anything, reboot.
    5) From RAID Controller cards BIOS, MIRROR Disk 0 to Disk 1
    Win XP has no idea there is a RAID setup, it's done before XP starts by
    the hardware controller card. Sure, you might be able to load a
    driver/manager that shows the status of the RAID controller/drives, and
    that driver might also allow you to manage the array, but it's done by
    the controller card (or onboard RAID controller chipset).
    Since you've not explained your drives, controller cards, or how you are
    doing RAID settings I can't really tell you what you did to lose the
    drives or how to recover it.
  6. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Hi,
    I have 2 160 Maxtor SATA drivers that are connect via SATA cable to my
    motherboard which has raid on board, I have a Asus - P4G8x Deluxe with
    Si3112r.inf as the silicon raid driver.
    I dont have an actual PCI raid card, Im using the motherboard feature. Then
    press F4 to setup the raid.
    Also on the note of how to do it I pretty much followed your step
    previously, however
    "> 4) Install Disk 1, don't do anything, reboot."
    When I installed the 2nd disk I didnt let windows startup, I jst created the
    raid?
    could this be the problem?
    > > dynamic?
    > 3) reboot
  7. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    In article <F1647329-BA72-4300-A1D3-B8D8D2E41313@microsoft.com>,
    > Hi,
    > previously, however
    > raid?
    Ok, now we're cooking:
    1) Was the disk 0 already connected to the onboard SATA RAID controller
    or did you have it connected to another SATA controller and then move it
    to the SATA RAID controller?
    2) From the RAID BIOS (not sure how to get into it on that board, F4
    sounds good), you setup your RAID by picking a drive as the source and
    another as the one to mirror too.
    3) As long as you installed the RAID controller drivers before you
    started this you should not have had any problem.
    Now, with the above said, I've seen many cases where a user has picked
    the WRONG drive to mirror to the second drive - they end up mirroring
    the unused drive over top of the OS drive and there is no recovery at
    that point - it's worse than formatting the drive.
    I think, based on all you've said, that you mirrored the blank drive
    overtop of your setup drive.
  8. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    My main disk was already connected to the onboard Sata raid controller. I
    dont have any other controllers apart from the standard MB one.
    Exactly, I created a raid and duplicated the source, I know that this was
    done correct, as when I use R-Studio (data recovery software) on both disks,
    I can see all of my data
    installed the RAID contoller drivers?? Im not sure what you mean, once i
    installed the new blank disk, all i did was switch on, go into the RAID bios,
    and created the raid. At no point it asked for any controller drivers, I
    mean the PC straight away recognised the 2nd disk, as the raid was
    successfully created.
    If this is the case, and I did mirror a blank unformatted, un partitioned
    drive to my used OS drive, when I use my data recovery software surely I
    wouldnt see a thing?
    thanks again
    > > Hi,
    > > previously, however
    > > raid?
  9. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    In article <AF6DA998-679F-4215-9EA4-C6B390C47CA6@microsoft.com>,
    The drivers may not be needed, some onboard raid controllers require a
    driver in order to use the drives once special functions are needed.
    So, maybe your BIOS is not set to boot to the RAID array, it's possibly
    setup to boot to the machine from the RAID array. Check in the BOOT
    section of the BIOS menu.
  10. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Hi,
    just checked the bios, and there is no refrence to any RAID in the bios, I
    checked to make sure its not jumper related either.
    I have just put the HDD back into the machine, loaded the RAID config
    utility, and deleted the RAID and re created it. I have:
    0 Maxtor 6B160M0 Curret
    1 Maxtor 6L160MO rebuild
    0 is the OS original
    Im rebuilding the raid then will reboot......if this doesnt work do you have
    any more ideas?
    btw you have been excellent help, really appreciate this
    DArren
  11. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Hi again,
    I have just recreated the mirror and still no joy.
    Just to clarify, the bios under boot does not have any ref to RAID nor SATA.
    All I have set is the 4.Other Boot Device to SCSI Boot device.
    There is no ref to RAID any where in the bios, all there is Onboard ATA
    device which is enabled.
    Am i missing something in the BIOS, if you want to see the manual please see
    http://dlsvr02.asus.com/pub/ASUS/mb/sock478/p4g8x/e1133_p4g8x.pdf
    "Darren" wrote:
    > Hi,
    > any more ideas?
    > DArren
  12. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    In article <3FAAE427-082A-434E-82A0-DB0E69C1D0CC@microsoft.com>,
    > Hi again,
    OK, I'm reading your motherboards manual right now - I had to download
    the older English one, the newer one only came in German.
    I'm looking at the 4-34/4-35
    It would seem that you need to set the following:
    1. Removable Device - Floppy
    2. Ide Hard Drive - NONE
    3. ATAPI CD-ROM - Pick your CD Drive
    4. Other Boot Device - see if your SATA shows up or some how you can
    pick the SATA drive array.
    Option #4 or #2 has to show the SATA drive or it's not going to work.
  13. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Hi guys
    Hope this may help you out. I have Raid0 on my ASUS p4p800 board , XP PRO.
    My Bios uses the Promise Raid Controlers.
    Look under the boot section of the bios,Boot Device Priority, click enter
    and you should see 3 boot options
    1st FT TX ARY 1 (my raid setup)
    2nd CDROM DRive
    3rd Floppy Drive
    The regular bios does not show the raid hard drives,you will not see any
    mention of them till the raid bios comes up.
    Is your onboard raid enabled?
    Hope this helps.
    Carl G
    "Darren" <Darren@discussions.microsoft.com> wrote in message
    news:A847674E-3FF7-418F-B1BD-088DCAE6C5EF@microsoft.com...
    > Hi all,
    > someone advise:
    > a
    > XP
    > I
    > FYI
    > data,
    > rebuild.
    > Darren
  14. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Hi Carl,
    I understand that I only have one bios for my system motherboard, I dont
    belive there us any other bios.
    #I think im going to have to rebuild.
    If i do is it better to set the raid up as one disk then install windows, or
    installed windows on one disk normally then set the raid 1?
    "Carl G" wrote:
    > Hi guys
    > 2nd CDROM DRive
    > 3rd Floppy Drive
    > Hope this helps.
    > Carl G
    > > Hi all,
    > > someone advise:
    > > a
    > > XP
    > > I
    > > FYI
    > > data,
    > > rebuild.
    > > Darren
  15. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Hi Darren
    When i install raid on my PC i have 2 hard drives set up to go,(i use 2 80
    gig).
    I boot from XP cd , first window hit F6 to install the raid Drivers, windows
    starts copying files then it will ask for the Flopy
    Disc, (which i had to create from the ASUS CDROM.
    When the pc reboots the first time you will see it go through the regular
    bios and next it will show the raid bios,
    then i have to hit ctrl and s key to create my raid aray.
    You can do it auto or manual,(chose the chunk size).
    when you are done with that window continues and you can partition and
    format the drive. (i use 2 80 gig so windows shows me 1 160 gig drive to
    work with. iuse 30 gig for windows and the rest for storage.I create the
    storage drive after i get windows up and running.)
    Hope this helps.
    Carl G
    news:EA67898E-6965-45F9-AE5B-4F59A8CD5C52@microsoft.com...
    > Hi Carl,
    > or
    > "Carl G" wrote:
    >> Hi guys
    >> PRO.
    >> 2nd CDROM DRive
    >> 3rd Floppy Drive
    >> Hope this helps.
    >> Carl G
    >> > Hi all,
    >> > can
    >> > someone advise:
    >> > created
    >> > a
    >> > the
    >> > windows
    >> > XP
    >> > that
    >> > I
    >> > FYI
    >> > access
    >> > to
    >> > data,
    >> > rebuild.
    >> > Darren
  16. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    By the way Darren, i use raid 0 so i don't have to do the copy thing.
    Carl G
    > Hi Carl,
    > or
    > "Carl G" wrote:
    >> Hi guys
    >> PRO.
    >> 2nd CDROM DRive
    >> 3rd Floppy Drive
    >> Hope this helps.
    >> Carl G
    >> > Hi all,
    >> > can
    >> > someone advise:
    >> > created
    >> > a
    >> > the
    >> > windows
    >> > XP
    >> > that
    >> > I
    >> > FYI
    >> > access
    >> > to
    >> > data,
    >> > rebuild.
    >> > Darren
NAS / RAID Windows XP
