Archived from groups: alt.comp.hardware.overclocking.amd (
More info?)
On Sun, 09 May 2004 15:38:00 GMT, Pete <peter@piper.org> wrote:
>Bit of a basic question really but I still need to ask it.
>Planning to buy a Chieftec BX-02 case and there doesn't seem to be a manual
>on the Chieftec site. I know a manual is a bit useless but I want to know
>where the fan openings are and what sizes go where, so I can order the fans
>when I order the case.
I'm confused with the ' 02 ' bit, what are the other numbers/letters
after ' 02 ' ? The reason for asking is the change in fan
size/location/thermal flow changes from April this year.
I have not yet had my hands on one of the ' 1904 ' spec but I have
built dozens under their OEM brand [ 18-1B & 19-2A ] I can however say
they are one of, if not the best case I have ever put together.
Changes are:
-rear x2 80's to one 120
-front x2 80's to one 120
-side none to x2 80-'s
In short does your case have [ two ] x2 80mm ' blow holes ' in the
side panel ?
>I don't plan to fit a full set of fans, unless it proves necessary. Now,
>given that I am not likely to be drastically overclocking my PC but are
>likely to have quite a few drives installed and that I live in England
>(where the room temperature rarely exceeds 22C or 72F), we get to my
>question.
>What comments/suggestions would you folk please care to offer regarding my
>fan population?
Other than that the case needs to be:
-positive pressure - just more in than out - REM your PSU has two fans
-quiet as possible - 2000 rpm is good enough
-direct cooled hard drives - SY-001-AK about a £iver from:
http://www.overclockers.co.uk/acatalog/Online_Catalogue...
and -no blind spots
>The set up will be a Gigabyte NNXP + AMD 2500 + 512megs of Kinston PC3200
>(another 512megs to be added later) + at least 3 hard drives, a DVD writer
>and a CD drive, all hanging off an Antec 430 watt True power supply.
Modern video cards produce a great deal of heat, hence the reason for
the side blow holes, I do however note that this 04 chassis does not
appear to have the top blow hole which was one of it's trademarks on
the previous builds.
>Hope you can please find the time to help me out.
>Thanks
>Pete
BoroLad
