OK, I usually use MAME32 and suddenly it will not run any games. I
click on an icon and it 'flashes' and dumps me back on the desktop. It
was working, and I have tried re-installing and deleting reg keys,
deleting the mame32ui file.
Any ideas, Mr Do is getting lonely ;-)
MAME(TM) - History In The Making...
MCR wrote on 24. April 2005:
> It was working, and I have tried re-installing and deleting reg keys,
* MCR wrote in alt.games.mame:
It cant find your roms.
David
If only one could get that wonderful feeling of accomplishment without
having to accomplish anything.
Solved it. It kicked up about being in a sub-directory! My goodness.
I moved it to F:\MAME and it worked. Strange indeed.
> Besides using Linux, no. ;-)
Do you know how long it took me to remove Linux? about 10 mins ;-)
> May be you just reinstall it, also get rid of the registry entries while
> deinstalling. Or use Linux. ;-)
None of it worked, and I dont think MAME32 works very well under GNU/Linux
Could be done faster.
>> while
I have the same problem.
Games only load when all options are set to default (Using
Options->Reset to Default...)
