Archived from groups: microsoft.public.windowsxp.hardware (More info?)
Can any one out there help with getting the wizard to stop the error given
after using the sound hardware test. Then the message saying use add/remove
DPVSetup.exe.
I have tried Mr. Microsofts solution to this. It is rubbish, it just does
not fix the problem. Does any one wish to share a sensible solution which
microsoft has not up to this point.
"XP home confused" <XPhomeconfused@discussions.microsoft.com> wrote in
message news:B4A49349-D4F3-4CCE-BD78-1AB6EB3433D0@microsoft.com...
> add/remove
> DPVSetup.exe.
Never heard of that problem,however if its a pci sound card,try moving it to a
diffrent slot on the board.If its integrated sound via the board,open
device mgr,
scroll down to the card,expand the tree,R.click on the
card,select,uninstall,then
restart computer.XP will reinstall at restart.
> DPVSetup.exe.
