Archived from groups: alt.comp.hardware.overclocking.amd (More info?)
"Daniel P" <none@none.com> wrote in message
news:UCqsc.16691$7y5.1841@fed1read03...
> Can something in a water cooling system break then spray water everywhere
Yes, but it's usually a leak-drip rather than Niagara.
Could do a lot of damage - like blow your mobo, vidcard and PSU.
It's often the result of moving pipes (which aren't infinitely flexible)
about, loosening clips, etc.
> If so how often would it happen?
Prolly never if you take care and check things once a fortnight.
> "Duct tape is a lot like the Force. It has a Dark side, a Light side, and
it
> holds all the pieces of the Universe together"
Obviously there is a possibility of leaks....just like there is a
possibility that anything else in your system will fail.
How often depends entirely on the quality of build and maintenance, it's a
good idea to check for leaks regularly....If you used distilled & deionised
water as coolant there is less risk because it's not conductive.
*****Replace 'NOSPAM' with 'btinternet' in the reply address*****
> Can something in a water cooling system break then spray water everywhere?
it
Sounds good. I have been thinking about water cooling for a while, but
since I would have to save for a year if it broke I have been to afraid.
Maybe I'll try it. What's a good watercooling kit for a guy on a budget.
"Duct tape is a lot like the Force. It has a Dark side, a Light side, and it
"BigBadger" <big_badger@NOSPAM.com> wrote in message
news:c8tn94$ilv$1@news8.svr.pol.co.uk...
deionised
everywhere?
and
> it
