Archived from groups: microsoft.public.windowsxp.hardware (More info?)
Carey...I can start and run my computer on A/C just fine without the battery
installed. My question is does it harm anything while running or while off?
Bill J
"Carey Frisch [MVP]" wrote:
> You'll have to replace the battery before attempting to use your laptop.
> Can you start your vehicle without the battery in place?
> Carey Frisch
> Microsoft MVP
> Windows XP - Shell/User
> Microsoft Newsgroups
> Get Windows XP Service Pack 2 with Advanced Security Technologies:
> http://www.microsoft.com/athome/se [...] hoose.mspx >
> "Bill J" wrote:
> | What effect does removing the battery from my lap top computer have while
> | using it on A/C and then storing the computer with battery left out?
I can't vouch for the battery removal at run-time issue, but many people run
on dead batteries for years as they either have given up on their use or
find replacing them too expensive.
- Tim
"Bill J" <BillJ@discussions.microsoft.com> wrote in message
news:42F30E40-C36B-4937-A401-357D50B708A6@microsoft.com...
> battery
> off?
> Bill J
>> Carey Frisch
>> Microsoft MVP
>> http://www.microsoft.com/athome/se [...] hoose.mspx >>
>> while
"Tim" <Tim@NoSpam> wrote in message
newsnmc$80iFHA.3540@TK2MSFTNGP14.phx.gbl...
but many people run
on their use or
| - Tim
message
without the
| > battery
running or while
| > off?
| > Bill J
use your laptop.
place?
| >> Carey Frisch
| >> Microsoft MVP
Technologies:
http://www.microsoft.com/athome/se [...] hoose.mspx | >>
computer have
| >> while
battery left out?
No effect. Note though, that this won't extend battery life if that's why
you're asking.
news:88165EAF-9824-42BA-9485-BF4B58D33C04@microsoft.com...
First, you can use the latpop without the battery if AC is providing power.
As to removing the battery, there's a big dependency on the way the laptop
manufacturer implemented the charging circuits. Best to check with them.
Incidentally, one of the methods of resetting a badly-hung laptop's BIOS
involves removing both AC and battery and pressing and holding the power
button.
The only problems you could have are:
1) Internal battery charger becomes defective (will not charge a battery.)
2) Battery loose its charge or does not keep a charge.
3) Laptop case cracks around the battery compartment.
If any of these occur and the laptop manufacturer confirms that this was
cause by a missing battery, this could void your warranty.
> have while
> left out?
most likly nothing, other then windows reporting that the batary is
ither missing or 0% charged (depends on the laptop). But if you do
with to remove the battary and run it on AC, switch the laptop off
first.
