Tom's Hardware Forums » Overclocking » AMD » Water Cooling
Water Cooling
Add a reply
 Word :   Username :
Bottom
Author
 Thread : Water Cooling
Del
Profile: stranger
More Information
Archived from groups: alt.comp.hardware.overclocking.amd (More info?)
Before I commit myself to nearly 200 pounds (370 us dollars) can anyone
recommend this water cooling system:
Zalman Reserator 1 Fanless Water Cooling System
Im buying it from this company http://www.chillblast.com/
It looks like the DOG's dangly bits! and I'm really impressed as it is
totally silent (has no fan at all)
Should i get this or is there a better system out there for the same price?
Related Pr oduct
Profile: stranger
More Information
If you're just after silent, this looks like a good piece of kit. If
performance is more your thing, get a kit from
http://www.coolercases.co.uk/water_cooling_kits.htm - something along the
lines of the TDX or RBX kits.
Profile: stranger
More Information
<del@here.com> wrote in message
news:40c4c885$0$258$c3e8da3@news.astraweb.com...
price?
It gets pretty good reviews, considering....
The issue is its a weedy little pump and very low flow rates, so you aren't
going to get brilliant cooling with the Reserator. Its probably comparable
to a good air-cooled copper heatsink (like the Thermalright SLK900) and
medium-speed fan. i.e. it won't break any records.
But -like you say - it is silent, and it does look cool.
Chip
Profile: stranger
More Information
Having said that you can fit your own pump with it ...
aren't
comparable
> Chip
More Information
del@here.com wrote in message news:<40c4c885$0$258$c3e8da3@news.astraweb.com>...
Cheaper alternative, buy water block (main component), get your own
big size water container, buy submersible fish tank pump, get water
horse, connect all components and it should work.
Del
Profile: stranger
More Information
So which one of these do I get??? they all look the same to me so why the
price difference?
Add a reply
Google Ads
News
Tclink demonstrates car-radiator based cooling system
Published on June 05, 2006
If regular computer cooling system aren't just enough, Tclink/Ebiz offers a liquid cooling system that uses an "automotive" radiator. Read more
IBM promises cooler chips with capillary-action and water jets
Published on October 27, 2006
IBM's Zurich labs have developed a new heatsink and water-cooling that promises to cool chips up to six times better than conventional air cooling. The heatsink contains tiny channels similar to the capillaries you would see in tree leaves and in human circulator systems. The channels allow either water or heatsink compound to spread more uniformly and thereby dissipate more heat. Read more
CeBIT 2008: RAM Watercooling By Gigabyte
Published on March 05, 2008
Gigabyte, more commonly known for its motherboards and graphics cards, is presenting a water cooling solution for RAM modules, dubbed Cool Rain. Read more
OCZ's 1150 MHz memory integrates liquid cooling
Published on November 21, 2006
If you enjoy squeezing every bit of performance out of your computer, then you are used to dealing with large and potent cooling systems already. Read more
Latest Reviews & Articles
Atom, Athlon, or Nano? Energy-Savers Compared
Published on October 03, 2008
We compared Intel’s Atom 230 and VIA’s Nano L2100 processors hoping to find the best product for low-power applications. VIA is in the vanguard of performance. Is this enough to beat Atom? Read more
Interview: Bigfoot's Killer NIC, Exposed
Published on October 02, 2008
Since its release, the Killer NIC has garnered a reputation for being an extravagant and largely unnecessary add-on for the do-it-yourselfer. Seeking additional insight, we approached the card's designer. Read more
Seagate's 1.5TB Barracuda: Bigger And Better?
Seagate is the first hard drive vendor to offer a 1.5 TB drive in the 3.5” form factor. Meanwhile, WD sent us its RAID Edition 3 (RE3) drive. We tell you which is the best HDD choice today. Read more
Updated CPU Charts 2008: AMD Versus Intel
Published on October 01, 2008
The processor is the heart of your PC, and our updated charts for Q3 2008 show 54 of them competing in terms of performance. Using our updated suite of benchmarks, compare your favorite AMD and Intel CPUs after reading this introduction. Read more
