Archived from groups: alt.comp.hardware.overclocking.amd (
More info?)
"Borchacz" <borchacz@wp.pl> wrote in message
news:caaavp$shl$1@atlantis.news.tpi.pl...
> Tell me or redirect to solution , please .
I'm presuming it's a 100MHz fsb duron, an easy step would be to fit PC133
ram and then set the fsb to 133, chances are that the duron will run fine -
if a little hotter. If so fit a cheap 80mm case fan to draw in some cool
air. When I overclocked my 600 all i did was to remove the heatsink & fan
assembly and carefully pencil in the L1 bridges on the face of the chip.
Google will be your friend in explaining this more. I already had PC133 ram
fitted. In the BIOS I just upped the fsb to 133 then upped the multiplier
one jump at a time (which you cant always do until you pencil the L1
bridges). In the end I settled for 7 x 125. Not too bad for a 600 with a
standard hsf (ie cost = 0 !). Exactly what mobo are you running?
chris
