DVD Drive Problem
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
Hi all, new to the forum :)
Anyway, I've got an unsual problem that I just can not work out. I've
got two DVD burners, one is a Pioneer DVR-109 and the other is a
Lite-On DVDRW SOHW-832S. Now, my pioneer burner is practically brand
spanking new, I haven't even burnt a DVD with it yet! It worked fine at
the start, and now it's just stopped reading CDs and DVDs all together,
I've updated firmware, no difference. I think I've just bought a dodgy
DVD drive, but thats not really my concern. My other burner, which is
also very new worked fine for ages, then started to stop working.
Would only read CDs and DVDs very slowly, but for some reason it
wouldn't read any type of Movie files, only data such as documents and
images. Now, it's totally died. CD/DVD loads up in Windows, asks what
action I wanna take (eg. music cd) I then load it up into winamp, all
the tracks load up, but nothing will play, it will just freeze winamp.
It's definitely not a winamp problem as the same thing happens if I load
up into Media Player. Also updated firmware, with no luck. After a
format, the Lite-On burner works fine for a few days... so I'm not sure
If possibly I've got a virus or some corrupt software I installed keeps
interferring with it. Really have no idea... any suggestions!?!?! :S
Thanks.
niko
2 answers Last reply
More about drive problem
  1. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    > Thanks.
    Impossible to say for sure without working with the hardware firsthand but
    every time I've had drives that work on and off, they were on their way out
    and ultimately needed replacing. DVD drives work with two lasers. It's
    possible for the DVD laser to be out of alignment yet still be able to read
    CDs. Your drives are both relatively new. Is there anything about the
    environment (heavy exposure to dust?) that might be knocking them out so
    quickly?
    Sharon F
    MS-MVP ~ Windows Shell/User
  2. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    In news:niko.1sq3pn@pcbanter.net,
    niko <niko.1sq3pn@pcbanter.net> had this to say:
    My reply is at the bottom of your sent message:
    > at the start, and now it's just stopped reading CDs and DVDs all
    > together, I've updated firmware, no difference. I think I've just
    > bought a dodgy DVD drive, but thats not really my concern. My other
    > burner, which is also very new worked fine for ages, then started to
    > stop working.
    > what action I wanna take (eg. music cd) I then load it up into
    > winamp, all the tracks load up, but nothing will play, it will just
    > freeze winamp. It's definitely not a winamp problem as the same thing
    > happens if I load up into Media Player. Also updated firmware, with
    > no luck. After a format, the Lite-On burner works fine for a few
    > days... so I'm not sure If possibly I've got a virus or some corrupt
    > software I installed keeps interferring with it. Really have no
    > Thanks.
    It could be corrupted Upperfilters or Lowerfilters, while the link below
    mentions specific products the fix is the same for currupted
    upper/lowerfilters. What types of software have you got installed that have
    to do with the optical drives? I've found that Nero's InCD seems to make my
    optical drives a bit buggy, meaning it needed to be removed and then the
    below done to make them work properly again.
    http://support.microsoft.com/kb/q270008/
    From Tweakomatic:
    Warning: Don't ever change a value in the registry. Ever. We know we just
    told you to do that, but would you jump off a cliff if we told you to? Don't
    ever change a value in the registry. Don't even say the word registry. We
    know a guy once who said the word registry, and three days later he was hit
    by a bus. True story. As a matter of fact, you shouldn't even have a
    registry on your computer. If you suspect that you do have a registry on
    your computer, call us and a trained professional will be dispatched to your
    office to remove the registry immediately. If you accidentally touch the
    registry, wash your hands with soap and water and call a doctor. Do not
    swallow the registry or get it in your eyes!
    By the way you're posting from PCBanter - a forum that leeches posts from
    the Microsoft Newsgroups. You might consider using a newsreader and
    accessing the newsgroups directly -- it prevents lost posts and the likes.
    Access MS Newsgroups :
    http://kgiii.info/windows/all/general/msnewsgroups.html
    Galen
    "But there are always some lunatics about. It would be a dull world
    without them."
    Sherlock Holmes
Burner DVD Drives Windows XP
