Archived from groups: alt.comp.hardware.overclocking.amd (
More info?)
Does anyone know a good OC program? I was thinkin that with a program I may
be able to raise my multiplier not my FSB
"Duct tape is a lot like the Force. It has a Dark side, a Light side, and it
holds all the pieces of the Universe together"
"Daniel P" <none@none.com> wrote in message
news:XwWzc.1984$8r5.121@fed1read03...
> I have a K8T-NeoFis2r with a Via K8T-800 Chipset. My sond card is a Sound
> Blaster Audigy ZS and I have medium sized heat sinks all over my chipset.
it
> "johny" <asdfae2@dfa.com> wrote in message
> news:LzSzc.42138$eu.34289@attbi_s02...
> > Keep in mind, its not only the CPU and Memory you're OC'ing, unless you
> have
> > nforce2 chipset.
> > What kind of Motherboard do you have, chipset? perhaps its your PCI
Sound
> > Card thats causing problems, or Nortbridge not being cooled properly.
> > I'm running A64 3200+ 2.0 GHZ on MSI Neo FIR2R K8T800 chipset, 2x512
> Corsair
> > XMS (with 18 activity LEDs) With stock cooling, I was able to get my FSB
> to
> > 213 and run stable, never Prime95'ed though. Built my watercooling days
> ago,
> > set my FSB to 220, boot up no problem, started 3DMark2003 to benchmark,
> > after few minutes it locked up, i restart, it doesn't boot, i get 8
short
> > beeps for Video Memory read/write error. After few minutes video card
> cooled
> > off and its fine now. Ordered RAMsinks from dangerden.com yesterday. I
> will
> > be trying to push FSB past 220 as soon as I get the RAM sinks.
> > news:t6Bzc.4148$Gy.2657@fed1read03...
> > > Hows this gonna help my problem?
> and
> > it
> > > "Scumball" <scumball@btinternet.com> wrote in message
> > > news:camdia$pph$1@titan.btinternet.com...
> > > > "Wes Newell" <w.newell@TAKEOUTverizon.net> wrote in message
> > > > news
an.2004.06.15.06.19.37.763690@TAKEOUTverizon.net...
> > > > > On Mon, 14 Jun 2004 04:35:50 -0700, Daniel P wrote:
> > > > > > I am having more and more problems OCing my A64 2Ghz. I am tring
> to
> > > get
> > > > it
> > > > > > up to atleast 2.2Ghz but Ill get there then me comp restarts.
Then
> I
> > > put
> > > > the
> > > > > > clock down to 2.1 and it runs stable for a few minutes then it
> > > restarts
> > > > > > again. Since I can get to the muliplyer I OC the FSB and dunno.
I
> > have
> > > a
> > > > > > 500w PSU and I have 3200 Kingston RAM. And all the while my
temps
> > stay
> > > > down.
> > > > Temps don't mean a great deal, counter-intuitively enough.
> > > > Your cooling's the critical factor.
> > > > Get an all copper Thermalright heatsink - and if you really want a
hot
> > > > clock, a 38 x 80mm fan.
> > > > > If your ram bus is set for 200MHz and you then set the System bus
to
> > say
> > > > > 215MHz, the ram bus also increases to 215MHz. Will that ram run
that
> > > high?
> > > > > Set ram to 166Mhz and try raising FSB from there.
> > > > > Abit KT7-Raid (KT133) Tbred B core CPU @2400MHz (24x100FSB)
http://mysite.verizon.net/res0exft/cpu.htm
