G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
Hi folks,
I'd like a bit of advice, if you will. It's about whether I should upgrade
my Mum's PC from Windows 98se to Windows XP.
Her system spec is:
SiS730 chipset motherboard / Socket A 810 Series
AMD Duron 1.1GHz CPU
384 MB RAM (PC133 SDRAM)
19GB Hard Drive
Onboard Sound, Modem, LAN and VGA (16MB)
It currently runs Windows 98SE, but I was wondering if it would run XP
efficiently. I've read the min spec. for XP and it certainly falls within
this, but what I want to know is: would it crawl along with XP or run along
at a happy speed?
Any advice gratefully received.
Thanks.
Gareth J M Saunders
Edinburgh, UK
Hi folks,
Her system spec is:
19GB Hard Drive
at a happy speed?
Thanks.
Gareth J M Saunders
Edinburgh, UK
