Archived from groups: alt.comp.hardware.overclocking.amd (
More info?)
Pavel wrote:
>>> Does Thermaltake Silent Boost K8 suit
>>> Gigabyte 7N400 Pro2 motherboard with Barton 2800+ ?
>> No.
>> Thermaltake makes another Silent Boost model for SocketA aka Socket
>> 462. That's the one you want. Part #A1889 or 1889-01.
> Thanks for answer.
> But, does Part#A1889 or 1889-01 suit Gigabyte 7N400 Pro 2
> motherboard?
> Some motherboards have special holes around slot which
> are required to install fan. Some fans require those holes,
> some not.
I could not reach the Thermaltake.com site on the day of my original post.
http://thermaltake.com/coolers/volcano/rs/a1889.htm
Either version uses a 6 lug clip to attach to the ZIF socket of the
motherboard. It is a good mechanical interface.
The only difference between the two products is the A1889-01 uses a dual
ball bearing fan rather than the slightly quieter Panaflo fan of the A1889.
Either one will fit your motherboard.
