Tom's Hardware > Forum > Overclocking > AMD > Whats the MOST effective cpu water cooler ?
Forum Overclocking : AMD - Whats the MOST effective cpu water cooler ?
Archived from groups: alt.comp.hardware.overclocking.amd (More info?)
For an Amd chip ?, would like it to be quiet as well but you know you
can't have everything.
Just want one that will alow me to overclock my Mobile 2500 to
2.8,2.9,3.0 ghz, so it needs to be very effective :)
Did a google but that was no help realy need some first and feedback
with people who have them installed and how well they work for them.
Thanks.
Sponsored Links
> Thanks.
Not sure but those kind of clocks sound as though they need phase cooling
rather than good old h20.
But as far as I know the danger den RBX is the best, but for better
performance a peltier/waterblock combo sounds more adequate for your
purposes.
Reply to Anonymous
Iam fine ill be happy with a 2.6ghz :), stock was 1.8ghz decent
overclock with normal coolinging anyway :)
>> Thanks.
>purposes.
Reply to Anonymous
Something the TDX should suit you ...
http://www.coolercases.co.uk/water_cooling_kits.htm
Reply to Anonymous
Thanks ill google some reviews and see if they are any good :)
Uk Product ? never heard of them ?, prob wont be able toget in my
country anyway :)
Thanks again.
On Fri, 2 Jul 2004 00:38:57 +0100, "Alex B"
Reply to Anonymous
"OCZ Guy" <ModenMr@yahoo.com.au> wrote in message
news:2k49e0pagvterk53mdmt59tjgunutmdllr@4ax.com...
> Thanks.
Why use water?
http://www.asetek.com/main/page.asp?sideid=385
Reply to Anonymous
Iam not that extream yet, maybe when they release some dual core
mobile XP 64bit cpus, ill slap in two on a dual board and go crazy :)
Ill stick to water for now.
Thanks.
On Fri, 02 Jul 2004 10:26:26 GMT, "rstlne" <.@text.news.virgin.net>
>> Thanks.
>Why use water?
Reply to Anonymous
> Why use water?
Maybe cos a top line kit costs less than half of one of those? Plus it's
quieter .... :-D
Reply to Anonymous
> Thanks.
Try:
http://forums.procooling.com/
Good board about watercooling, smart people in there and a lot of info
you can pick up. You can also check out:
http://www.procooling.com/
http://www.overclockers.com/
They both have some very good reviews.
If you want to get a premade kit, try something from Swiftech, the new
6000 series stuff is nice, if you want to go with a mix and match, check
out stuff from:
http://www.dtekcustoms.com/
http://www.dangerden.com/
To reply, replace 'deadfishies' with 'bigfoot.'
We live our life in our own way, never ever listen to what they say, the
kind of faith that never fades away, we are the True Believers!
Reply to Anonymous
"Alex B" <Freeflyer91@hotmail.com.NOSPAM> wrote in message
news:cc4ubk$1st$1@newsg1.svr.pol.co.uk...
> 35 is waaaaay to noisy for me. Anything above about 22 annoys me. It'd
be
> nice to have a negative cpu temp though !!
3 22 fans in your system will probably come up to 30
add in the power supply and you'll probably be above 35..
Reply to Anonymous
I mean 22 total. My psu is inaudible at more than about 20 cm's away (unless
it's really hot).
"rstlne" <.@text.news.virgin.net> wrote in message
news:DHvFc.27$s21.7@newsfe2-gui.ntli.net...
> be
Reply to Anonymous
There are 915 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
