Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Missing sound card driver issue
Forum Windows XP : Windows XP General Discussion - Missing sound card driver issue
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
My friend recently had her sound card stop working. It appears that the
drivers were wiped out somehow. Normally i could help with this, but she
doesnt know what her sound card is, and its a laptop so i cant open it up to
find out. It's a Gateway and the model number is PA1700-02AB (she doesnt know
what model it is so thats all i can give you)
Is there any easy way to discover what card she has or what drivers to get?
Sponsored Links
Correction: she thinks its a Gateway M505.
Reply to Anonymous
> the drivers were wiped out somehow. Normally i could help with this,
> but she doesnt know what her sound card is, and its a laptop so i
> cant open it up to find out. It's a Gateway and the model number is
> PA1700-02AB (she doesnt know what model it is so thats all i can give
> you)
> to get?
ummm. www.gateway.com *might* help?
Q
Reply to Anonymous
- 0 +
If its a laptop the 'sound' is supplied by the laptop manu
"NoL devin" <NoLdevin@discussions.microsoft.com> wrote in message
news:E998A95F-77D1-430A-9160-C14202015A0B@microsoft.com...
to
know
get?
Reply to dl
thanks for the help so far, but the gateway site was no use (we found the
"right" drivers, but they were designed to run in dos, no use on xp.)
Reply to Anonymous
I don't have a Gateway M505, but isn't the 9525327 package the one that you
need? (The package is supposed to include Realtek drivers for XP.) It's a 5
MB download.
It is a Winzip self-extractor. The "readme" that comes with it specifically
describes it as being for XP.
Address scrambled. Replace nkbob with bobkn.
news:3FB97497-BB49-492E-9718-B560B35AAD09@microsoft.com...
Reply to Anonymous
i believe thats the one we tried, when she ran it she got a dos error,
whining about autoexec.nt and such.
Reply to Anonymous
Then see here:
Error message when you install or start an MS-DOS or 16-bit
Windows-based program:
http://support.microsoft.com/defau [...] duct=winxp
This can also be caused by malware. Is your friend's computer completely
virus and malware-free? If she thinks so, what did she do to determine
this? Here are some general malware removal steps:
http://www.elephantboycomputers.co [...] ng_Malware
If she is absolutely sure the machine is clean, then AVAST (antivirus
software) can be the cause if you have WinXP SP2 installed:
http://groups.google.com/groups?th [...] omcast.com
You can put back the standard version of autoexec.nt/config.nt by
copying a backup copy held in %windir%\repair\ to %windir%\system32\
(%windir% is typically C:\Windows) instead of using the procedure in
the KB article above.
Make sure the computer is clean, fix the autoexec.nt issue, and then try
and install the proper drivers you got from Gateway.
Malke
MS-MVP Windows User/Shell
Elephant Boy Computers
www.elephantboycomputers.com
"Don't Panic"
Reply to Malke
thanks for the help, but i couldnt manage to get the gateway ones working.
malke i tried what you said but it didnt help, and that was the exact error i
got too. we went to realtek's website and got the drivers for the AC'97,
since thats the one gateway had drivers for, its all fixed now.
Reply to Anonymous
There are 1255 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
