Archived from groups: alt.comp.hardware.overclocking.amd (More info?)
I have a XP 2600+ thoro, bus 333 MHz, and a mobo Epox 8rda chip NForce2.
I can set cpu multiplier freely between 5 and 12.5, and it's all ok.
But i cant start pc setting cpu multiplier at 13x166 (like an XP 2700+).
What is the problem?
Is the cpu multiplier stopped over 12.5 ?
If yes, can i unlock it? and how?
>Thank
Did you raise the Vcore a step or two?
Usually a little boost in voltage to the CPU is needed when OCing them.
> NForce2. I can set cpu multiplier freely between 5 and 12.5, and it's
> all ok. But i cant start pc setting cpu multiplier at 13x166 (like an
> XP 2700+). What is the problem?
Yes. yes. Don't worry about it and just raise the FSB speed. 12.5 times
172 would equal a 2700+. 12.5x180 would be a 2800+. You will/may need to
raise vcore the higher you go.
Marco<maneig@tin.it> oskarzony (a) napisa³(a) na dan± grupe o porade
> Thank
