G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
Can Someone help.
I have a HD issue with a Dell 4500s....
My HD does not show up on the Bios in the Dell (original HD for the
Dell)
but when I hook it up as a slave on another Pc it seems fine, & even
when I put it on as the master it seems fine on the bios. I had to
erase the os on the Dell because i had issues previously. So I wanted
to transfer 98 se onto the so called problematic HD. Then I wanted to
upgrade to xp. ( Mind you I only have a XP home upgrade). So what
should I do (Norton's ghost imaging is out of my budget). My Dell I
beleive didn't come with a HD installion disc since it was manufatuor
installed. So that could be a problem...
lachef2121
Can Someone help.
Dell)
lachef2121
