Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > USB problem and Metrologic Bar Scanner
Forum Windows XP : Windows XP General Discussion - USB problem and Metrologic Bar Scanner
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
We are a business with approximately 110 Dell Latitude Laptops, D550, D600,
D610 all running XP Pro which is continually updated. For unknown reason
after use for several days the Metrologic bar code scanners attached to the
USB quit working. The USB in device hardware shows no problems or conflicts
but too, when putting in the 3 1/2 in floppy drive which is also USB in
attempts to re-image the machine the the floppy is not recognized. It took
awhile but Dell is replacing Motherboards as a solution but we are at loss as
to what causes the problem. The was at one time a Dell service issue about
scanners not getting enough power to run from the USB ports but the article
has been removed. Any ideas anyone? Appreciate your help, Thank You.
Sponsored Links
Probably a power issue USB ports supply only 500mA per port. An optical
mouse uses 100mA no telling how much the scanner or floppy uses but if it is
more then that it will not work. Also a laptop will not supply full power
like a desktop if it is running on batteries.
The best live web video on the internet http://www.seedsv.com/webdemo.htm
NEW Embedded system W/Linux. We now sell DVR cards.
See it all at http://www.seedsv.com/products.htm
Sharpvision simply the best http://www.seedsv.com
"Jeff C" <JeffC@discussions.microsoft.com> wrote in message
news:BEFAB3F4-213A-427A-B5A7-8941ED896410@microsoft.com...
> D600,
> the
> conflicts
> took
> as
> about
> article
Reply to Anonymous
Jeff,
If your running _110_ Dell Latitude Laptops, and can't get support on
this issue from Dell or Metrologic, why would you do business with
these folks in the future?
Look under Device Manager, USB properties, and find out how much each
usb device is drawing. Usually 500Ma is the limit. You could try
connecting the bar scanner to a powered hub, to see if that corrects
your problem.
Best,
Treeman
Treeman
Treeman's Profile: http://www.msusenet.com/member.php?userid=1260
View this thread: http://www.msusenet.com/t-1870981359
Reply to Anonymous
There are 948 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
