WinXP No Longer Recognizes My Sound Card
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
I'm running WinXP with SP2 on a Compaq mini-tower. Within the past week, some
kind of corruption must have set into the registry keys that control my
Creative Audigy 2ZS Sound Card.
On at least 3 start-ups recently, WinXP had to rediscover my sound card
under Device Manager. On two of those occasions, it warned me that the newly
discovered hardware might not work properly. The sound card continued to
work for several days more, however---until I suddenly lost all sound
capability.
Looking in the Device Manager, I found a new device icon for an undefined
"Multimedia Device Controller". By deleting this item and restarting, I
forced the Device Manager to recognize it once again as the Audigy Sound
Card. But there is a Code 10 error message ("The Device Will Not Start")
appearing in the Device Manager profile for the sound card.
I have the latest version of the driver software for this card. I can't
install it, however, because WinXP doesn't recognize that the card
exists---even though it still appears under Device Manager. It's obvious that
I need to fix something in the registry. But there are so many keys, I don't
know which ones to change.
6 answers Last reply
More about winxp longer recognizes sound card
  1. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    On Wed, 17 Aug 2005 18:01:01 -0700, Martin
    >capability.
    In the device manager. Try rolling back your driver and don't let
    windows update download the new driver. I had to change automatic
    update to notify only. This way I can choose to hide the updates that
    I don't want. Each new version of the driver you will have to hide
    the update again. I had a problem with my modem driver. I use the
    feature modem on hold. I get notified of an incoming call. Then I
    disconnect. You may need to reinstall your original driver.
    Greg Ro
  2. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    The original driver is currently installed. There's nothing to roll back to.
    And I can't re-install the original driver (or install the latest driver)
    because WinXP doesn't acknowledge that there is a sound card.
    I have only two options: repair the registry or do a complete re-install of
    the OS. Is there any way to locate the defective registry keys?
    > Greg Ro
  3. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Try the sound card in a different slot.
    Its allways possible sound card or mobo has a fault.
    "Martin" <Martin@discussions.microsoft.com> wrote in message
    news:5C589CE7-5939-4FDB-820B-857DF9882C61@microsoft.com...
    to.
    of
    > > Greg Ro
  4. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    >to.
    >of
    >> > Greg Ro
    If it not on onboard sound card. You will need to disable the
    on-board sound in the bios. Then xp should recognize it.
    Greg Ro
  5. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    If you have installed the driver, you can always "remove" them from
    Add/Remove Programs. If the driver install will not go thru, head oveer to
    forums.creative.com. The Audigy card are "rumored" to be sensitibve and the
    sound card's "prom" can get screwed up. Heard this for Audigy and Audigy 2
    card but not the ZS cards.
    news:E362D3ED-36CA-44B0-BA99-46C4BC8726F4@microsoft.com...
    > some
    > newly
    > capability.
    > that
    > don't
  6. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    > some
    > my
    > Creative Audigy 2ZS Sound Card]
    > I don't know if this will help you when I upgraded to XP my system
    > appeared to have no sound card. See entry from tigerlilly a couple of
    > days ago. I had to get new drivers for my chipset from the
    > manufacturer.Maybee try getting new drivers from the manufacturer of
    > your sound card. Good luck I hope you solve it.
    tigerlilly
Device Manager Sound Cards Windows XP
