Archived from groups: microsoft.public.windowsxp.hardware (More info?)
I'm trying to get the clicks to work on a brand new Microsoft wireless
optical notebook mouse on a Thinkpad T42 running XP Professional. Apparently,
there are some known issues according to article 321122. I followed all the
steps described in it but the clicks still don't work.
I even used Intellipoint 5 instead of 5.2. Nothing seems to help.
This is really frustrating. Expert guidance needed urgently.
mgana Wrote: > I'm trying to get the clicks to work on a brand new Microsoft wireless
> optical notebook mouse on a Thinkpad T42 running XP Professional. > Apparently,
> there are some known issues according to article 321122. I followed all > the
> Thanks.
Try deleting the driver for it and reinstalling it again.
1. Load and install the driver in the computer first without have anything turned on or plugged in to it.
2. Restart the computer and then start turning on everything. Make sure everything is turned on like the access point and the mouse.
Also, try moving the access point to a better location for better reception. Check to see if you have dead batteries or what not.
The pointer moves correctly and the signal strength is indicated as good.
It's something to do with the driver which seems to be incompatible with XP
SP2. Dumping SP2 is not an option. Anybody have any ideas? The Microsoft
article steps didn't help. Is there a patch out there or something?
> > Apparently,
> > the
> > Thanks.
> Goodl luck with it
> Evolution54
mgana Wrote: > The pointer moves correctly and the signal strength is indicated as > good.
> It's something to do with the driver which seems to be incompatible > with XP
> SP2. Dumping SP2 is not an option. Anybody have any ideas? The > Microsoft
> mgana Wrote:-
> I'm trying to get the clicks to work on a brand new Microsoft > wireless
> Apparently,
> there are some known issues according to article 321122. I followed > all
> the
> Thanks.-
> 2. Restart the computer and then start turning on everything. Make > sure
> Goodl luck with it
> Evolution54
Hmmm....if the pointer moves but the buttons don't function, I would try and return it for a new one. Why don't you try and install it on another computer to see if it is hardware or software related. I don't think it should be imcompatible with SP2 because it is a Microsoft product. Try it on another computer and post the results. Thanks
I had it replaced. It was indeed a faulty piece.
New one works fine now.
Thanks!
> > good.
> > with XP
> > Microsoft
> > mgana Wrote:-
> > wireless
> > Apparently,
> > all
> > the
> > Thanks.-
> > sure
> > Goodl luck with it
> > Evolution54
> Evolution54
mgana Wrote: > I had it replaced. It was indeed a faulty piece.
> Thanks!
> mgana Wrote:-
> good.
> with XP
> Microsoft
> mgana Wrote:-
> wireless
> Apparently,
> all
> the
> Thanks.-
> sure
> Goodl luck with it
> Evolution54
> another computer to see if it is hardware or software related. I > don't
> Evolution54
Right on! Indeed its weird that even new pieces of hardware fails because that have never happened to me. But glad everything is working for you now.Peace!
