Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Hard drives Disconnecting only the power connector
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
I have hard drives that I rarely use an in order to prolong their life
I disconnect the 4 pin power connector.
Am I creating any problem by not disconnecting the 80 conductor
cable ?
Thanks
Vlad
Sponsored Links
You are not creating a problem by not disconnecting the IDE cable. However,
you should know that today's hard drives can spin 24/7 for many years,
almost certainly longer than you will be using the computer, without any
problems.
Ted Zieglar
"You can do it if you try."
"Vlad" <x@> wrote in message
news:iu2pg1hp3ait5eu9fg57e9dnp3de2gmoqm@4ax.com...
> cable ?
> Thanks
> Vlad
Reply to Anonymous
You may be prolonging the drive's life but you are doing nothing about the
power connector.
> cable ?
> Thanks
> Vlad
Reply to Anonymous
- 0 +
On Wed, 24 Aug 2005 11:20:45 -0400, "Ted Zieglar" <teddyz@notmail.com>
>problems.
Lately I have replaced 5 hard drives . All of them about 5 years old.
That was the main reason to have them OFF.
At one time I installed 4 dpdt switches to enable the power supply
disconnect of the drives. I have since remove them but, based on your
information, I am thinking of installing a single switch to turn off
the power on 2 hard drives. I want them to last longer them me. I am
not asking much, I am 75.
I know that there is a future project on the way that allows the
switching of the power of the drives that are compatible with the
new system . This is mainly to conserve power.
Thanks for the help
Vlad
Reply to Vlad
- 0 +
On Wed, 24 Aug 2005 11:52:08 -0400, "Yves Leclerc"
>power connector.
True but that connector must have been specified by a power company.
Compare with the new ones used on the serial drives. From one extreme
to the other.
Regards
Vlad
>> cable ?
>> Thanks
>> Vlad
Reply to Vlad
news:lj4pg1hglo0iednq0n4accdh8ruhk0ibck@4ax.com...
>>However,
>>problems.
That's interesting. I've replaced more customer hard drives because of
failures in the last month than in the previous 7 years at this location.
I've had a few of my own drives go bad.
And there's nothing in common among these drives -- different ages,
different manufacturers, different types of drives.
Reply to Anonymous
There are 519 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
