Archived from groups: microsoft.public.windowsxp.hardware (
More info?)
Ok, but how do I do this?? This is foreign to me. Thanks
"WarOfGenesis" wrote:
> you dude just do this make sure you have you wiring done correctly once you
> do that you wont get the errorr message again.
> make sure you dont have too many deivces on one power lead, for exmaple have
> one for DVD rw(s) and one or for HHD that should be ok
> "Cari (MS-MVP)" wrote:
> > The Power Supply Unit is what connects the PC with the Power... it works out
> > what power is needed to each and every device inside the PC.
> > If you PC is only a month old, backup any documents and other files you need
> > and call the manufacturer. (Chances are high they will format the drive
> > when repairing it).
> > It's certainly possible the PSU is faulty. They should replace it if they
> > test it and find a problem..
> > Cari (MS-MVP)
> > Printing & Imaging
> > "EmergencyNurse" <EmergencyNurse@discussions.microsoft.com> wrote in message
> > news:A7F6978C-5801-4086-9F8B-6C455A54D730@microsoft.com...
> > > what is a psu and what does that mean? It is a month old comp. thanks...
> > >> Have you added any other hardware snce you last burned a DVD/CD
> > >> successfully? If so, it could be your PSU (power supply unit) is
> > >> insufficient for the amount of hardware you are now running. If not, it
> > >> could be your PSU is failing and needs replacing.
> > >> Cari (MS-MVP)
> > >> Printing & Imaging
> > >> message
> > >> news:A462711A-8A23-4FC2-A854-C3DE281472D8@microsoft.com...
> > >> > What is this, and why is it happening? I have tried lowering my write
> > >> > speed,
> > >> > hasent worked. This is a month old computer and I cant find any info on
> > >> > help
> > >> > for this problem. I have run system restore, not helped.
> > >> > I have burned many cds and dvd in the past with no problem then all of
> > >> > a
> > >> > sudden .....this error. Thanks
