Ghosting system to a different drive number & BOOT.INI
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
Frome what I've gathered from various posts, Ghosting an IDE master to
an IDE slave almost always works because the new drive can be made to
look like the same drive number simply by changing the master/slave jumper.
However, what if the new drive is on another IDE channel (disk 2 versus
disk 0/1) or a SATA drive (disk 4). Such a drive can't be made to look
like the original boot IDE by jumpering, and boot.ini references the
drive and partition number. If these don't match the physical location
of the new drive, Windows won't boot correctly.
What's the recipe to successfully cloning to a different disk number and
have it boot as drive C:?
11 answers Last reply
More about ghosting system drive number boot
  1. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Animated Shockwave Ghost tutorial with sound
    http://www.symantec.com/techsupp/tutorial/ghost_2002/2001032917165825_s.html
    How to perform a disk-to-disk clone
    http://service1.symantec.com/SUPPORT/ghost.nsf/pfdocs/2001032917165825
    Carey Frisch
    Microsoft MVP
    Windows XP - Shell/User
    Microsoft Newsgroups
  2. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    "Pat Coghlan" <info@coghlan.ca> wrote in message
    news:jDpPe.851$Ld.326645@news20.bellglobal.com...
    > Frome what I've gathered from various posts, Ghosting an IDE master to an
    > IDE slave almost always works because the new drive can be made to look
    > like the original boot IDE by jumpering, and boot.ini references the drive
    > and partition number. If these don't match the physical location of the
    Pat:
    In terms of a disk imaging program such as Symantec's Norton Ghost or
    similar program, a clone is a clone is a clone. It makes no difference how
    the drives are connected/configured at the time the clone is created. All
    that is essential is that the user select the correct source and destination
    disks when he or she performs the cloning operation..
    After the clone is created, one should ordinarily disconnect the source disk
    and boot to the newly-cloned drive. In most (but not all) cases it makes no
    difference how that newly-cloned (IDE/PATA) disk is connected/configured,
    i.e., whether it's on the Primary or Secondary IDE channel or whether it's
    configured as Master or Slave. In most (but again, not all) cases (assuming
    you've created a viable clone), the system will boot to that drive. There
    are, however, motherboards that will refuse to boot to a bootable drive if
    it's not connected/configured as Primary Master. And we've come across a few
    motherboards that would permit a boot only if the drive was connected on the
    Primary IDE channel (regardless of whether the drive was connected as Master
    or Slave). In both cases it involved only a relatively few motherboard
    models.
    The important thing to remember is that following the disk cloning operation
    to boot to the newly-cloned drive that's the *only* storage device connected
    during that initial boot whether it's a PATA or SATA drive.. Afterwards it
    makes no difference if both drives are connected.
    Anna
  3. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    > Yes, but boot.ini points to a disk # and partition #. I think
    > everything has to match in order for the new drive to boot
    > successfully. I'm not sure how the disk # is determined though.
    boot.ini entries include the term "rdisk()" which refers to
    the HD's relative position in the BIOS's HD boot order.
    The HD named at the head of the list is at relative position 0
    and it's referred to as "rdisk(0)". "rdisk(1)" refers to the HD
    at the next position in the HD boot order, etc. By looking
    at the HD boot order in the BIOS, you can see what all the
    rdisk() values refer to.
    The partition numbering for boot.ini starts with "1" for the
    1st partition, and the term for the 1st partition is "partition(1)".
    The boot.ini file used in the boot process is the boot.ini
    in the "active" partition of the HD that is at the head of the
    BIOS's HD boot order and which has a good Master Boot
    Record (MBR). The ntldr program in that "active" partition
    displays the contents of the boot.ini file, and it loads the OS
    in the partition indicated in the boot.ini entry that is selected -
    either by time-out or manually by the user. Note that the OS
    to be loaded can be in any partition on any HD in the system.
    This also means that you can have several partitions with
    the boot.ini/ntlder (and ntdetect.com) files to perform the
    loading operation. The one to do it will be the one marked
    "active" on the HD that is at the head of the BIOS's HD boot
    order. And the HD boot order can set manually in the BIOS
    by the user for full control over which boot.ini defines the
    OSes which can be loaded.
    *TimDaniels*
  4. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    > Er, but if the original drive is reconnected, it will once again be the
    > detected by the BIOS as the first bootable primary partition, marked as
    > drive 0 and Windows will boot from there, no?
    > Heck, I disabled the primary IDE channel in the BIOS and I still ended
    > up with my old D-drive mapped! I'm pretty sure if I reconnect it and
    > enable the primary IDE channel, I'll be booting off it again. I'm going
    > to take it straight to its new home - a drive upgrade for my in-laws
    > computer.
    This has more to do with the motherboard BIOS than Windows. Some
    motherboards will always boot from an IDE device on the primary controller
    no matter how you set things up. Sometimes if you change the boot order to
    SCSI first it will work, Some motherboards you can pick the drive you want
    to be active. Some refuse to cooperate no matter what you do. If this is the
    case then you can't boot from a SATA drive if a PATA drive is installed.
    Kerry
  5. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Are rdisk() and disk() mutually exclusive then? What is disk() used to
    specify?
    I would assume, then, that if a user clones a drive to a different
    partition number, the new drive will either not boot or boot a different
    OS, if present.
    So the "active" partition is really just a starting/launch point.
    Thanks for the explanation :-) Much appreciated.
  6. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    > specify?
    I don't know exactly what multi() and disk() are used for. In ALL
    multi-booting operations that I've done using several clones on
    several HDs, I've never had to touch those parameters in the
    boot.ini file. A search in www.Microsoft.com might reveal
    something, but those parameters are certainly not well
    documented.
    > OS, if present.
    That is correct. There are two solutions. I use a generic boot.ini
    that allows booting to any of 4 partitions on 3 HDs. (This leaves
    out the 3rd and 4th partitions of the 3rd HD since ntldr seems
    only to display 10 boot menu entries.) Thus, any "parent" and
    any clone have the means to boot any OS in the system. You
    could also edit the clone's boot.ini file after cloning but before
    the clone is booted for its 1st time by booting up the "parent"
    OS with the clone present. Remember, though, that the
    meaning of the argument in "rdisk()" changes with the BIOS's
    HD boot order, so if you remove the "parent" HD, the next HD
    in the boot order (usually, but not necessarily, the clone) becomes
    rdisk(0).
    That is correct. It contains the loading and loading info -
    what some call the "boot manager", i.e. boot.ini/ntldr/
    ntdetect.com files. That "loading partition" is labeled by
    Disk Management as the "system" Local Disk (i.e.
    partition), and the partition containing the OS that gets
    loaded it labels the "boot" Local Disk. Microsoft's use of
    "boot" and "system" in this case seems counter-intuitive,
    but Hey!, that's Microsoft.
    It's all buried in the Microsoft online documentation for
    Windows XP, and it takes some plowing, so few people
    have waded through it. Let me know if you figure out
    multi() and disk().
    *TimDaniels*
  7. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    >>>drive
    >> Anna wrote:
    >>Pat:
    >>destination
    news:Hb-dnQb6oKYYOZPeRVn-pA@rogers.com...
    > I got it to work tonight, but there were a few quirks. For example,
    > after the SATA drive came up as the C-drive, the old D-drive (2nd
    > partition on original boot IDE) appeared...even though I had disabled
    > the drive in the BIOS! The old drive was still connected, but only the
    > 2nd partition got mapped to a drive letter. Luckily the old C-drive was
    > nowhere to be seen. I went back and disconnected it and restored D: on
    > the 2nd SATA partition a second time, after which I had my D-drive back.
    >>disk
    >>no
    >>(assuming
    >> >>few motherboards that would permit a boot only if the drive was
    >>connected on >>the Primary IDE channel (regardless of whether the drive
    >>was connected as >>Master or Slave). In both cases it involved only a
    >>models.
    Pat continues:
    > Again, as long as the new drive number matches what is in boot.ini
    > everything should work, but what if the drive number in boot.ini is
    > hijacked by another drive (or is this impossible, assuming that the
    > drive containing the first bootable partition is assigned as drive 0 by
    > the BIOS)?
    Anna again:
    >>operation
    >>connected
    >>Anna
    Here's Pat again...
    > computer.
    Pat:
    With all due respect, you're making this process of cloning the contents of
    one hard drive to another hard drive much more complicated than it need be.
    Please forget about BIOS detection, modifying the boot.ini file, drive
    letter assignments, drive numbers, jumper settings, and the like.
    As I previously stated, the process of cloning one internal HD to another
    internal HD is relatively simple & straightforward. With your two drives
    (source and destination) connected, you use a disk imaging program such as
    Symantec's Norton Ghost or Acronis True Image to identify the source disk
    (the drive you're cloning FROM) and the destination disk (the drive you're
    cloning TO). Two or three keyclicks later the cloning process begins. And
    that's it at this point. No need to modify BIOS settings, no need to change
    drive letter assignments, no need to modify the boot.ini file (or any other
    file), etc., etc.
    After the cloning operation has been completed, you disconnect the source
    disk and boot up with the destination disk to check that you now have a
    viable (bootable) clone. To repeat what I stated before...
    In most (but not all) cases it makes no difference how that newly-cloned
    (IDE/PATA) disk is connected/configured, i.e., whether it's on the Primary
    or Secondary IDE channel or whether it's configured as Master or Slave. In
    most (but again, not all) cases (assuming you've created a viable clone),
    the system will boot to that drive. There are, however, motherboards that
    will refuse to boot to a bootable drive if it's not connected/configured as
    Primary Master. And we've come across a few motherboards that would permit a
    boot only if the drive was connected on the Primary IDE channel (regardless
    of whether the drive was connected as Master or Slave). In both cases it
    involved only a relatively few motherboard models.
    If you've cloned to a SATA drive the system will ordinarily boot to that
    drive without incident.
    After you've determined that the cloned drive is bootable, you may want to
    change its connection and jumper setting (assuming it's a IDE/PATA disk) to
    Primary Master *if* you now want to use that drive as your new working HD.
    And, in that instance, of course, you'll change the connection/configuration
    of your former source disk. Otherwise, no changes are necessary if you're
    simply going to use the newly-cloned drive as your backup drive.
    Anna
  8. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    "Anna" wrote:
    > Pat:
    > file), etc., etc.
    > Anna
    That is correct. For making a clone to replace the existing OS
    hard drive, you don't have to do anything with or know anything
    about the BIOS's HD boot order, the boot.ini file contents, and
    which partition is marked "active". Using Cable Select (for
    Parallel ATA HDs), you don't even have to fiddle with jumpers.
    Just put the "parent" at the end connector of the cable and the
    clone-to-be at the intermediate connector, do the cloning, then
    remove the "parent" HD and put the clone HD in its place, and
    fire it up.
    An understanding of what you're doing is only necessary if you
    do multi-booting, and a deeper understanding is necessary
    only if you put several OSes on a single HD.
    *TimDaniels*
  9. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    > fire it up.
    Do programs like Ghost clone an entire physical drive (including MBR and
    all partitions) or just individual partitions? In the case of the
    former, the new drive will be a replica of the old drive in terms of
    number of partitions and their types...with additional unallocated space
    on it. In the case of the latter, there must be an underlying assumption
    that the original drive has Windows in the first (primary) partition and
    that the clone is being performed to the first primary partition on the
    new drive, otherwise there is the potential for the clone to not work as
    expected.
  10. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    >> fire it up.
    > and all partitions) or just individual partitions? In the case of the
    > expected.
    Ghost 9.0 (and its predecessor, Powerquest's Drive Image 7)
    clone a designated partition at a time. During the setup of the
    process, the options are given to clone the MBR and to mark
    the resulting partition "active". There is no assumption about
    the position of the source partition. In Casper XP, the MBR
    is copied if the destination HD doesn't have one, and the
    resulting partition is marked "active" (if I recall correctly). For
    cloning, I prefer the simplicity (and lower price) of Casper XP.
    Casper XP also does NOT require MS's .NET Framework,
    but since .NET Framework will be needed for more and more
    apps in the future, that may be a moot advantage.
    Partition Magic will also clone single partitions, but PM wants
    first to compact the partitions together that may already exist
    on the destination HD before making its clone, and that can
    take a lot of time - approximately the time to do a cloning for
    each partition that is moved. Since I use clones to keep
    several archived copies of an entire OS as immediately-
    bootable backups on a single large HD (on a removable tray),
    such shuffling of partitions are prohibitive for me.
    Of course, the newer partitions are a little larger (generally) than
    the ones that they are replacing. So what I do before cloning
    a partition is to use Partition Magic to shrink the partition a
    little to remove some of its unused space. Then it will fit into
    the space left by a partition that has been removed to make
    way for it on the archival HD.
    *TimDaniels*
  11. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    What I should have said is:
    "In case the newer partition may not fit exactly into the space of
    the older partition which it will replace, I use Partition Magic to
    shrink the new partition a little to remove some of its unused
    space."
    *TimDaniels*
Ghosting Boot Windows XP
