cpu killed power supply, why?
Archived from groups: alt.comp.hardware.overclocking.amd (More info?)
Hi all
Hopefully this is the best news group to post this query. I have/had
amd athlon 1600+ cpu, chaintech motherboard and 512mb of ram running
windows xp. Friend of mine had a computer that died after a power
surge and wanted to check what bits were dead by component swapping
with my machine. it was a msi motherboard with a 900 duron cpu.
Hard drive was fine then he tried the duron900 cpu in my motherboard.
When turned on the power supply was sort of going half speed up and
down for about 3 seconds then smoked up. It killed my power supply and
as yet I don't know what else doesnt work as I have not got a new one
installed.
How can a spiked duron900 wipe out a power supply like that?
Just interested is all.
thanks for any replies
darrin
new zealand :):)
3 answers Last reply
More about killed power supply
  1. Archived from groups: alt.comp.hardware.overclocking.amd (More info?)
    "Gimmee" <thecrowatnz@hotmail.com> wrote in message
    news:41610a12.5480858@news.nzwide.ihug.co.nz...
    > Hi all
    > installed.
    > darrin
    > new zealand :):)
    It cant..
    Chances are the motherboard or power supply had problems..
    Just because it doesnt turn on doesnt mean it's not the power supply.. If a
    spike went through the system then putting bad parts in good working kit
    can have problems.. So a duff processor might kill the board..
    But a duff processor wont kill the board in a way that it will kill the
    processor..
  2. Archived from groups: alt.comp.hardware.overclocking.amd (More info?)
    To kill a power supply, the supply had to be defective when
    purchased. Review even Intel specifications for PSUs. It
    lists wir size to short out all power supply outputs - and
    still the power supply must not fail. But today, too many
    computer experts assume they don't need no stink'in training.
    Therefore they don't even know basic electrical concepts nor
    do they even read the Intel requirements. This has created a
    lucrative swamp for Asian power supply manufacturers to dump
    inferior supplies at even higher profits.
    For example, what do the written specs with that power
    supply say. Did it specifically list these and so many other
    necessary criteria? And was this provided in writing?
    Specification compliance: ATX 2.03 & ATX12V v1.1
    Acoustics noise 25.8dBA typical at 70w, 30cm
    Short circuit protection on all outputs
    Over voltage protection
    Over power protection
    100% hi-pot test
    100% burn in, high temperature cycled on/off
    PFC harmonics compliance: EN61000-3-2 + A1 + A2
    EMI/RFI compliance: CE, CISPR22 & FCC part 15 class B
    Safety compliance: VDE, TUV, D, N, S, Fi, UL, C-UL & CB
    Hold up time, full load: 16ms. typical
    Efficiency; 100-120VAC and full range: >65%
    Dielectric withstand, input to frame/ground: 1800VAC, 1sec.
    Dielectric withstand, input to output: 1800VAC, 1sec.
    Ripple/noise: 1%
    MTBF, full load @ 25°C amb.: >100k hrs
    I doubt it which is why the power supply failed. Any computer
    assembler with minimal electrical knowledge appreciates how
    important things in this list are to computer integrity.
    Apparently your supply did not have at least some of these
    functions and therefore probably did not even provide written
    numerical specs.
    Now we get to an even more dangerous fact. A failing power
    supply must never damage any computer hardware. If your
    supply was missing essential functions, then another function
    not installed may have been the circuit that keeps power
    supply from damaging or overstressing any other hardware.
    We build and repair computers only to learn. We don't do
    this to save money. We do it to be smarter. Take this
    problem and learn from it. Learn the many functions that must
    be in all power supplies - even 30 years ago.
    Fourth point: swapping to fix things is foolish especially
    when simpler, faster, and more accurate methods are
    available. Two discussions demonstrate how to perform this
    all faster and more accurately with the ubiquitous 3.5 digit
    multimeter:
    "Computer doesnt start at all" in alt.comp.hardware on 10
    Jan 2004 at http://tinyurl.com/2t69q or
    "I think my power supply is dead" in alt.comp.hardware on
    5 Feb 2004 at http://www.tinyurl.com/2musa
    Again, gain from your problems. Learning from mistakes is
    essential. Learn why any computer assembler with basic
    knowledge knows and uses even a 3.5 digit meter to even find
    problems before they happen.
    Gimmee wrote:
    > Hi all
    > installed.
  3. Archived from groups: alt.comp.hardware.overclocking.amd (More info?)
    So true, so true ... I think it's much worse in the overclocking scene
    though, where people are doing voltmods without even knowing what a resistor
    is.
    > nor
    The first part of this statement is true, but the second part is vacuously
    true. Taking a look at a couple of what I would classify as damn high-end
    PSUs:
    [1] PCP&C Turbocool 510 series. You can grab the specs at:
    http://www.pcpowercooling.com/products/power_supplies/maxperformance/turboco
    ols/hp_510atx.htm
    [2] Antec True550. Specs are at
    http://www.antec.com/specs/true550_spe.html
    [3] Forton 550W (FSP550-60PLN-R). 24-pin ATX, but close enough :) Specs from
    http://www.fsusa.com/Product/FSP550-60PLN.pdf
    There are possibly pages with more info than these, so feel free to correct
    me :)
    To do the cheap end, I used the box for my Hyena ( = Foxconn = Allied =
    millions of other names) "500W" PSU, and the bit of paper that came with it.
    Note: I may have got some of the first thee PSUs mixed up below, but the
    Hyena was done later so the values in the Hyena's column should all be
    correct.
    Stepping through the requirements:
    PCPC: [Y], Antec: [N], Fortron: [N/A (EPS12V)], Hyena: [Y]
    I'm presuming Antec just forgot to list it, or presumed it was obvious.
    [N], [N], [N], [N]
    [Y], [N], [Y], [Y]
    PCPC: implied through overcurrent protection presumably
    [Y], [N], [Y], [Y]
    [Y], [N], [N], [N]
    PCPC Listed as over-current protection
    > 100% hi-pot test
    [N], [N], [Y], [Y]
    [N], [N], [Y], [Y]
    [N,N,N], [N,N,N], [N,N,N], [N, N, N]
    [Y, N, Y], [Y, Y, Y], [Y, Y, Y], [Y, possibly, Y]
    "Possibly" because I have no idea what the CISPR22 symbol looks like and
    there's a great big line of them on the side of the box, so possibly it's in
    there.
    Incidentally, it's quite fun hunting for CE symbols on obscure things. So
    far I've found it on my ski goggles, a model london bus, and a can of
    flyspray :)
    , , , [D, N, S, FI,
    CB, TUV, UL]
    [Y], [N], [Y], [N]
    [Probably], [Y], [N], [Y]
    PCPC only said "70%" without stating conditions or whether it was a minimum.
    [Y], [N], [N], [N]
    [N], [N], [N], [N]
    > Ripple/noise: 1%
    [Y], [Y], [Y], [Y]
    [Y], [N], [Y], [N]
    So three of what I would regard as very close to top-of-the-line power
    supplies failed a multitude of the tests. The generic Hyena didn't do to
    shabbily, but this is possibly due to having a bit more space to print all
    these things. Not to say I think the Hyena is anywhere near any of those in
    terms of quality. I'd swap it in the blink of an eye for any of those if I
    could.
    I would be very surprised if any PSU (besides the Seasonic 400W supply that
    you copy'n'pasted this from, complete with grammatical mistakes :) )
    actually list all of the above (and possibly even complied with, given the
    range of safety and EMI standard that are listed). This doesn't mean it's a
    bad power supply, as demonstrated above. If a power supply *did* have all
    the features listed above (ignoring the non-safety related ones like EMI,
    acoustic, ripple, etc) then I would agree that it's pretty much only
    possible to blow the PSU if the PSU is defective (which can't be ruled out
    for any manufacturer).
    Michael Brown
    www.emboss.co.nz : OOS/RSI software and more :)
    Add michael@ to emboss.co.nz - My inbox is always open
AMD Power Supplies CPUs Motherboards Overclocking
