thart :
i Bought it from Office max it has beeen installed for about a year now when i up graded the computer ther wernt any issiues
this problenm just started about 2months ago and today i started the lap top and everything is fine the sound works and it
says it is a legit copy of windows. thre are no virsus on the computer im thinking that it might be somthing on the board or a cable
inside?
Good details here, that's the kind of info you want to put in the first post, helps with figuring out what is going on.
You may be having an issue with the motherboard, but if this issue only happens once in a while, I'd let it be. To replace a motherboard on a laptop is close to the price of a whole new system. The audio should not have a cable to get loose, unless the jacks are pulling off the system board. However is the chips overheat, they can have unpredictable results.
You may want to make sure your vents and fans are clean (compressed air should do it).
