Tom's Hardware > Forum > Overclocking > AMD > What are Motherboard Monitor's two 'hoops' in system tray?
Forum Overclocking : AMD - What are Motherboard Monitor's two 'hoops' in system tray?
Archived from groups: alt.comp.hardware.overclocking.amd,alt.comp.hardware,alt.comp.hardware.pc-homebuilt,alt.comp.hardware.homebuilt (More info?)
When I run Motherboard Monitor I see two hoops on the right hand edge
of XP's system tray.
Here is a pic of it.
http://freespace.virgin.net/openac [...] _hoops.GIF
The hoops still appear even if I display apps like IE in full screen
mode.
http://freespace.virgin.net/openac [...] screen.GIF
What do the hoops do and what do they indicate?
Sponsored Links
"Jan Yeero" <nomail@thankyou.com> wrote in message
news:9584737AEE101A4D@130.133.1.4...
What piece of hardware is this related to? Why not try asking in a group
that is acutally related to your problem?
Better yet, did you read the help file that came with it?
Reply to Anonymous
"Jan Yeero" <nope@nomailtoday.com> wrote in message
news:9585AB3B42BB71F3M4@204.153.244.156...
> >> hand edge of XP's system tray.
> This relates to a homebuilt PC which I want to overclock. The config
> is quite power hungry and I want to avoid memory errors and the like
> from poor voltage/temperature control of the motherboard and its
> peripherals.
My bad... I'm sorry... really. For some reason I read "Network Monitor"...
My guess is that the two "o" symbols are degree symbols. Haven't been in the
settings for MBM for a while, but I'm guessing that you have the "Use a
windows font..." selected on the "Tray & OSD" section. I'm looking at
v5.3.5.0.
BTW, I appreciate the civil reply as well.
Hope this helps a bit.
Reply to Anonymous
On Sun, 17 Oct 2004 01:03:07 +0100, Jan Yeero
<nope@nomailtoday.com> wrote:
<snip>
You are in error.
It is software. This is not a software newsgroup.
The crossposting was excessive too and didn't specify a
followup group.
FURTHER, it is quite selfish to expect someone to do your
work for you, but to not let anyone else benefit from it in
the future with the "X-No-Archive: yes".
RTFM!
Reply to Anonymous
>> config is quite power hungry and I want to avoid memory errors
>> and the like from poor voltage/temperature control of the
>> motherboard and its peripherals.
> Monitor"...
Hey, no problem. I make bigger mistakes than that!
> been in the settings for MBM for a while, but I'm guessing that
> you have the "Use a windows font..." selected on the "Tray &
> OSD" section. I'm looking at v5.3.5.0.
No it's not a degree symbol. It's far too far away from any MBM temp
icon.
Reply to Anonymous
x-no-archive: yes
> <snip>
> You are in error.
Kony, my posting relates to a software utility which is used only to
understand hardware behavior.
I reckon you wouldn't complain about a software memory usage monitor being
dicussed, you probably wouldn't complain about BIOS settings being
discussed. Nor about hardware reporting utilities like AIDA/Everest,
Sandra, FreshDiagnose, PC Wizard, etc. These are software too.
So why make an issue now out of MBM?
I guess maybe you got up on the wrong side of the bed that day you posted.
> followup group.
I guess you are right about over-crossposting. I try to limit myself to 4
as advised by the standards. But I came across so many hardware groups it
was hard to do it this time. Apologies if it upset you. I will bear that
in mind.
Got to say that I hate FollowUp-To because if I am a regular visitor to only
one of the crossposted groups then I will miss the rest of the thread even
if I actually reply to it.
You seem to insist on FollowUp-To and just for you I will use it but I
believe it loses people who might have been interested in the outcome but
who don't want to subscribe to a new group.
At least RFC 1036 explicitly allows 'Followup-to' to name multiple groups so
I will choose a small subset of two.
Sorry about the X-No-Archive. However no later reader will miss much
because any replies (like yours) will quote the relevant parts of the text.
According to the RFC, X-No-Archive is only a request and databases are free
to ignore it. It was implemented only releavtively recently in an RFC
update so it can be assumed to be a viable option.
> RTFM!
RTFM? But it's not in the manual.
If you can guess the answer then maybe you should be able to say some more.
Jan
Reply to Anonymous
Archived from groups: alt.comp.hardware.overclocking.amd,alt.comp.hardware.pc-homebuilt (More info?)
On Sun, 17 Oct 2004 12:11:16 +0100, "Jan Yeero"
<nomail@nomail.com> wrote:
>x-no-archive: yes
>> <snip>
>> You are in error.
"I reckon" is somehow a fortune-telling event?
There is a reason why newsgroups are divided into different
categories. Use of software to troubleshoot or otherwise
deal with hardware issue (among other diagnostic measures)
is on-topic. Simply wanting discussion of software alone is
not.
Stop guessing and learn why usenet is divided into
categories.
>> followup group.
>in mind.
Not a manner of being "upset", it simply conflicts with
efficient flow of information to have everything duplicated
into as many conceivable newsgroups as possible, let alone
all off-topic groups. If this were practiced all the time
there would be thousands of posts in every group, inundation
to the point where none work as efficiently anymore.
It's not that difficult to follow a thread either way.
.... but it is still fragmented and there is no assurance the
entirety of the opening post is copied, though some of it
may be relevant.
Yes they can ignore it, but what's the signficance of that?
It still limits many people's access to information unless
they are a select few who have forethought to access a
database that ignores it.
>> RTFM!
I suspect the info is out there but you didn't look.
Reply to Anonymous
>>> On Sun, 17 Oct 2004 01:03:07 +0100, Jan Yeero wrote:
>>> <snip>
>>> You are in error.
>>only to understand hardware behavior.
>>monitor being dicussed, you probably wouldn't complain about
>>BIOS settings being discussed. Nor about hardware reporting
>>utilities like AIDA/Everest, Sandra, FreshDiagnose, PC Wizard,
Charter for comp.hardware.overclocking.amd says:
"Postings concerning applications, methods, and techniques for
overclocking, hardware configuration, cooling, power supply,
software, benchmarking, reliability testing, measurement, and related
subjects are welcome."
NB 'Applications'.
[snip] [snip]
>>> RTFM!
>>some more.
I can't find it. Can you?
Reply to Anonymous
> mode.
What makes you think they have anything to do with MBM?
Chip
Reply to chip
>> screen mode.
>> http://freespace.virgin.net/openac [...] lscreen.GI
>> F
I stop MBM and the two hoops go away.
I restart MBM and they come back.
Do you see them when you run MBM?
Reply to Anonymous
"Jan Yeero" <yanyo@mail.com> wrote in message
news:9587A3FEA96071F3M4@204.153.244.156...
>>> screen mode.
>>> F
Oh I see. Very odd.
No. Actually I don't run MBM, but when I did, I didn't get the hoops.
Sorry I can't help
Chip
Reply to chip
There are 1326 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
