G
Guest
Guest
Archived from groups: alt.comp.hardware.overclocking.amd (More info?)
A7N8XE-Deluxe, Rev 2
Barton XP2600-M at 1.65V and 1666MHz (for now ;-)
Speeze Whisper Rock II, .55C/W
Kingmax MPXC22D-38LT3R 2x512MB PC-3200 CAS 2.5
MBM 5.3.7.0
WinXP-SP1
Both the Asus Hardware Monitor and MBM indicate a CPU socket temp of 38
deg idle and 41 deg at 100%, with case temp of 18 deg indicated, but 22
deg measured with a thermometer in the case. I want to go ahead
overclocking the machine (my first attempt), but the CPU temps seem kind
of low, and I'm wondering if I can trust them. I'd like to measure the CPU
temp some other way as well, as a cross-check, but the A7N8X-E/MBM
combination won't allow CPU diode readings, as far as I know. Is there
another way to do it?
And based on your own experience, does 38 deg idle/41 deg at 70% seem
about right for this CPU?
Thanks for any/all input!
MBM 5.3.7.0
WinXP-SP1
