G
Guest
Guest
Archived from groups: alt.comp.hardware.overclocking.amd (More info?)
I have been thinking about water cooling this system to make it cool
more efficiently and quietly, and I have a few questions:
1.) Do I really need to buy a pre-built water block, or can I remove
the fan from my heatsink and encase it in a (very well sealed of
course) plexiglass box? I have an Antec Solution Series heatsink for
Socket A, and it has microfins, would this restrict circulation?
2.) Instead of using a radiator, can I build a small copper tank for
the water to flow through and attach a small peltier cooler to the
outside to remove some of the heat? If I placed an 80mm fan next to
the peltier on exhaust or intake would it be enough to dissipate the
excess heat?
3.) Would doing this be any cheaper than purchasing a pre-built kit,
like the ThermalTake Aquarius II watercooling kit? Would the
difference in price be significant enough to justify building my own?
Thanks in advance,
-Hukuis
excess heat?
Thanks in advance,
-Hukuis
