Tom's Hardware > Forum > Overclocking > AMD > HELP!! SEMPRON 2200 epox nforce 2 ultra 400 ( memory 256 k..
Forum Overclocking : AMD - HELP!! SEMPRON 2200 epox nforce 2 ultra 400 ( memory 256 k..
Archived from groups: alt.comp.hardware.overclocking.amd (More info?)
what should i do to overclock fsb to 200 Mhz??
which voltage should i turn up??
i set
1.725 cpu
1,6 AGP (radeon 9550)
chipset default
and it doesn't work :((((
Sponsored Links
> i set
> 1.725 cpu
> chipset default
Sempron is not good for overclocking unless you get the socket 754 sempron.
Reply to Anonymous
> i set 1.725 cpu
> chipset default
Lower ram timings. Even when you get it going it's not going to give you
much of an increase in clockspeed with only a 9 multiplier and only a
33MHz increase of FSB speed. The default speed is 1500MHz (9x166) and
only 1800MHz at 9x200. I know it's not consolation now, but a socket A
Sempron is a poor choice for a performance cpu. See Sempron in link below.
Abit KT7-Raid (KT133) Tbred B core CPU @2400MHz (24x100FSB)
http://mysite.verizon.net/res0exft/cpu.htm
Reply to Anonymous
"vollam" <vollam@wp.pl> wrote in message
news:d363d16.0412101605.3966e661@posting.google.com...
> i set
> 1.725 cpu
> chipset default
isnt sempron multiplier locked?
does the board support 200 fsb?
cpu voltage should be 1.6 ish 1.68 ish i would say anyhw
Reply to Anonymous
There are 904 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
