Archived from groups: alt.comp.hardware.overclocking.amd (More info?)
On Sat, 1 Jan 2005 16:35:44 GMT, "Yaff" <novirus@JUNKaei.ca> wrote:
>Hi Guys,
>Just got myself a A8V w/ AMD64 Winchester 3200+ (default 2000mhz)
>I've read some crazy guys OCing it at 2995mhz...
>I'm happy with mild stuff and the machine is rock solid stable at 2400mhz
>(240x10) running with cpu voltage to its default 1.4v
>If stable at 1.4v, then should I leave it there or should I increase the
>voltage anyway?
>Thanks for the info
No sense in adding voltage if not needed. If running windows, try Prime
95's FPU torture test. My 3200+ Newcastle fails the FPU test if vcore is
set too low.
"Yaff" <novirus@JUNKaei.ca> wrote in message
news:mZWdnSh_e_ITREvcRVn-gA@giganews.com...
> Thanks for the tip Ed,
> I'll do that.
> One thing dought. My Radeon X800 XT is no longer stable at 1.5v, I have to
> put it at 1.6v
> Does this .1v increase will shorter its life?
No, many graphics cards need 1.6v AGP these days. In fact often
manufacturers recommend it. Its nothing to worry about.
"Yaff" <novirus@JUNKaei.ca> wrote in news:9P6dnQFBr93_TEvcRVn-
rA@giganews.com:
> Hi Guys,
> voltage anyway?
Leave it. My 3200+ Winchester is running at 2500MHz at the stock voltage
and passes the Prime95 torture test.
