Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Bizarre network adapter problem
Forum Windows XP : Windows XP General Discussion - Bizarre network adapter problem
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
My network adapter does not appear in Device Manager, until I "Show
hidden devices". And then it appears as a "Realtek RTL8139 Family PCI
Fast Ethernet NIC", whereas I actually have a D-Link DFE-538TX 10/100
adapter.
Furthermore, I get no icons (at all) in the Network Communications
window. So if I want to change any settings of my LAN, for example, I
can't, because I can't select the LAN icon or right-click on it. The
LAN is working though. The current driver for the Realtek adapter which
is listed is a MS driver. Attempts at installing the latest D-Link
driver or Realtek version results in the device failing to start (with
"Code 10", whatever that is.)
I have tried the following:
- everything in the MS KB825826 article
- all my PCI settings are at Auto in the BIOS
- uninstalling the adapter (can't because "device may be needed to boot
the machine" )
Any ideas?
Sponsored Links
Thanks Malke. Is the new network card necessary? My LAN is working ok -
I log into to my work network and use the internet etc. It's just that
there's no icon in Network Communications, and also the strange Device
Manager behaviour detailed above. So it's not that it's not working,
just that Windows doesn't see it, even though Windows is using it.
Strange. I have actually tried uninstalling it (intending to let
Windows find new hardware, and then direct it to the driver of my
choice) but Windows won't uninstall it. An winow appears informing me
that the device "device may be needed to boot the machine".
Any more thoughts?
Reply to Anonymous
> - I log into to my work network and use the internet etc. It's just
> that there's no icon in Network Communications, and also the strange
> Device Manager behaviour detailed above. So it's not that it's not
> working, just that Windows doesn't see it, even though Windows is
> using it. Strange. I have actually tried uninstalling it (intending to
> let Windows find new hardware, and then direct it to the driver of my
> Any more thoughts?
I did not realize that your network is functional. If everything is
working and you don't need the icons, then leave well enough alone.
Malke
Elephant Boy Computers
www.elephantboycomputers.com
"Don't Panic!"
MS-MVP Windows - Shell/User
Reply to Malke
Ah if only it were that easy! I need to change some of the IP settings,
for example, and since I can't access the window to do that (which
would be a right-click), I'm pretty stuck. Any ideas?
Reply to Anonymous
<googlegroups@higginsnet.com> wrote in message
news:1127137478.681010.250680@g14g2000cwa.googlegroups.com...
You can change all IP parameters via a Command Prompt using
netsh.exe. Example:
netsh interface ip set address "Local Area Connection" static 125.187.7.56
255.0.0.0
Reply to Anonymous
Hi,
This might help:
Troubleshoot Missing Network Icons in Windows XP
http://support.microsoft.com/defau [...] -us;825826
- Janus
news:1126865744.481152.308410@f14g2000cwb.googlegroups.com...
> adapter.
> the machine" )
> Any ideas?
Reply to Anonymous
There are 1100 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
