Archived from groups: comp.periphs.printers (More info?)
Printer run out of ink, I replaced all cartridges and I now get an error
message stating out of ink which obviously isn`t the case.
Anyone know how to resolve this?
"ArchieNlsn" <archienlsn@aol.com> wrote in message
news:20040730093430.04869.00000636@mb-m05.aol.com...
> any help appreciated.
> thanks
If it's anything like my 3200, you use half the new ink during install ..
bastard companys
I dont have that printer, but it sounds to me like you do indeed have a 2nt
dry ink cart, maybee the store you bought it from will check it for you?
can you feel the weight difference
Sometimes you may need to take out the cartridge,shake it lightly then put
it back in!
> thanks
A number of things can cause this. I'm assuming you are using Epson OEM
cartridges.
The contacts that read the cartridge chip may be dirty, damaged or
missing. The chip on one of the cartridges itself may be dirty, damaged
or missing.
There was a series of cartridges released that appear to be Epson OEM
(can't say for sure as Epson's cartridges have been counterfeited very
well) that were reported by numerous people as being defective in terms
of their chip. Assuming you bought these as OEM Epson (even is they end
up being counterfeit) I suggest you call Epson and tell them about the
problem. In the cases I heard about, they shipped the people new
cartridges. Only one cartridge needs to be reading empty for the
printer not to work.
While you're at it, you might wish to tell Epson what you think about
their putting a technology into their printers which offers you NO real
advantage, makes the printer and cartridges more costly to make, thwarts
competition, by trying to make it difficult for 3rd parties to produce
consumable (against the Sherman Anti-Trust Act in the US) and creates
problems such as this.
The only advantage I know of that this system allows for is that the
information on how much ink is "supposed to" be in the cartridge is
carried with the cartridge itself, rather than the printer, allowing you
to change cartridges mid-stream or placing partially used ones in
without the printer running out of ink during printing. The only reason
this is even important is that Epson heads can develop air locks if the
cartridge is run to empty making it difficult to restart the ink flow.
Instead of spending so much money and engineering time on coming up with
ways of trying to stop people from refilling the cartridges, or from
being able to source 3rd party product, they could have spent the
efforts fixing the air lock and potential clogging problems.
Art
> thanks
By the way, with the CX5200, you have individual cartridges for each
color. Why did you replace all the cartridges? I would only replace
the one that showed up as being near empty.
Art
>>thanks
This should have no effect. Epson printers do not actually read the ink
levels in the cartridge. The printer reads the chip, subtracts the
assumed usage based upon your printing session, and then rewrites the
chip to a lower number. It is all a bit inaccurate. The printer never
"knows" the real amount of ink in the printer. Yes, you should shake
the cartridge for the Durabrite ink cartridges because the pigment in
the ink settles.
You can try removing and reinstalling the cartridges in hope a bad
connection between the chip and the chip contact wire will be corrected.
Art
> it back in!
>>thanks
>> thanks
>bastard companys
Ink Tank not fully seated or chip contacts dirty or not making contact
Life is not measured by the number of breaths we take, but by the moments that take our breath away. (George Carlin)
I had a similar problem with a C82 epson replaced the carterages and
everything worked fine. BTW I had a total of 3 (of 4) new cartarages turn
up out of box bad that month.
As I have previously mentioned, either Epson OEM or some well made
counterfeits have been showing up which have bad cartridge chips. If
this happens to you, contact Epson about it. At least in recent past,
they were replacing these cartridges.
Art
Arthur Entlich <artistic@telus.net> wrote in
newsKZOc.5551$yT2.2160@clgrps13:
snip
The only reason
> the cartridge is run to empty making it difficult to restart the ink
> flow.
> with ways of trying to stop people from refilling the cartridges, or
> from being able to source 3rd party product, they could have spent the
Ah, yes, the old air lock problem. My in-laws tried to get all the ink
they could out of their CX5200 ink cartridges. They let the yellow run
dry, and when they replaced it, nothing would print yellow. They
performed enough cleaning cycles trying to get the thing to work again
that they used up most of the cyan and magenta, too. The machine was a
month out of warranty, so they junked it and bought a CX6400. They
won't let this one run dry.
They had a full set of unopened OEM CX5200 inks that they bought months
ago. When the CX6400 needed its first black cartridge replacement, they
assumed they could use the CX5200's cartridges in the CX6400. Nope.
BTW, any idea why the CX6400 takes so long to print? That is, from the
time you hit print to the time it starts printing, it takes about 10
seconds, even with simple text documents. All settings are the same,
factory default, as were with the CX5200, whose time to print was fast.
In Epson's defense, I will say that they are good on their warranties.
While their CX5200 was still under warranty, the scanner stopped
working. One call to Epson to troubleshoot, and Epson determined it
was hardware related. They sent out a new CX5200 in two days (it had
all new inks), freight paid.
