Old power supply- new pci-e motherboard!
Anonymous
Power supply Expert
Motherboard Authority
Overclocking Expert
Archived from groups: alt.comp.hardware.overclocking.amd (More info?)
Not sure if the additional 4 pin connecter you reference is earmarked for
another socket. For instance the DFI SLi mb requires 4 power connections to
the mb for stable SLi mode. A 24 pin main, a 4 pin atx 12 volt, a hdd and
floppy drive power lead. Four connections total. Your motherboard manual
should show how to make the proper connections.
"Dan" <d@d.com> wrote in message
news:420b689b$0$16589$cc9e4d1f@news-text.dial.pipex.com...
> My brand new SLI motherboard has got a 24 pin power connector, and my
power
> supply has a 20 pin power connector and another lead which looks like 4
> power pins (what are they?) Can I use the 20pin cable and put the 4 pin
> cable in the missing holes?
> Thanks
> Dan
Anonymous
Power supply Expert
Overclocking Expert
Dan wrote:
> My brand new SLI motherboard has got a 24 pin power connector, and my power
> Thanks
> Dan
Thats what its made for. Just plug 4 pin connector into "missing holes"
and it will work just fine.
Related ressources
Anonymous
Power supply Expert
Overclocking Expert
Dan wrote:
> Thanks! I'm assuming I have to be careful what holes I put the two
> connectors into?
> Dan
There is only one way to put them in. Otherways they wont fit.
Anonymous
Power supply Expert
Overclocking Expert
>connectors into?
>Dan
Dan for Christsakes don't do this the seperate 4 pin connector is not
designed to connect there. The 4 pin has its own header usually close
to the processor socket. The 24 pin ATX power socket is designed to
accept either the standard 20 pin plug or the new ATX 2.0 24 pin plug.
The M/B should come with a blanking plate fitted over the spare 4
sockets which are left over if you use the 20 pin plug.
Anonymous
Power supply Expert
Overclocking Expert
> power supply has a 20 pin power connector and another lead which looks
> like 4 power pins (what are they?) Can I use the 20pin cable and put the 4
> pin cable in the missing holes?
No, but you can get a 20->24 pin adapter (ATX->ATX 2.0). The 4 pin
connector is an extra +12v connector. Should be a place on the MB to plug
it in. RTFM.
Abit KT7-Raid (KT133) Tbred B core CPU @2400MHz (24x100FSB)
My server http://wesnewell.no-ip.com/cpu.htm
Verizon server http://mysite.verizon.net/res0exft/cpu.htm
Anonymous
Power supply Expert
Overclocking Expert
>> 4 pin cable in the missing holes?
Well I don't think it will fit and that's a good thing since it would
probably blow the MB. That's NOT what it is for. Suggest you check the
difference between the ATX (20pin) and ATX 2.0 (24pin) specs before you
spout such trash again. The 4pin (P4) connector is 2 +12v pins and 2
ground pins. The extra 4 pins of the 24 connector are 1 each, +3.3v, +5v,
+12v, and Ground IIRC.
Ask the community
