G
Guest
Guest
Archived from groups: alt.comp.hardware.overclocking.amd (More info?)
Here's the max specs.
32A@+3.3v
32A@+5v
26A@+12v
1A@-5v
1A@-12v
2.2A@+5vsb
Someone correct me if I'm wrong, but doesn't VxA=W?
So then the watts would be roughly 100, 160, 312, 5, 12, 11, for a total
of 600W. Is this correct?
Yet the specs say that the combined max output of +3.3 and +5v is
185Watts, and the PSU is a 350W max ouput.
So what do the rail ratings really mean? If you use all 312W of +12v, you
only have 38W left to split between the other voltages?
Now I have another PSU with these max specs.
32A@+3.3v
40A@+5v
24A@+12v
..5A@-5v
1A@-12v
2A@+5vsb
So then the watts would be roughly 100, 200, 288, 2.5, 12, 10, for a
total of 612.5W. Now this PSU is rated for 550W, so what's up with it?
Which would you want?
Abit KT7-Raid (KT133) Tbred B core CPU @2400MHz (24x100FSB)
My server http://wesnewell.no-ip.com/cpu.php
Verizon server http://mysite.verizon.net/res0exft/cpu.htm
32A@+3.3v
32A@+5v
26A@+12v
1A@-5v
1A@-12v
2.2A@+5vsb
32A@+3.3v
40A@+5v
24A@+12v
..5A@-5v
1A@-12v
2A@+5vsb
