fan speed and noise reduction
Charles
341
Archived from groups: alt.comp.hardware.overclocking.amd (More info?)
I am running an AMD Athlon XP 2000+
I think it is running at either 1.6 or 1.8 Ghz
In an effort to reduce noise, I removed the
factory fan/heatsink and replaced it with a
"Cooler Master X Dream II" which claims to
have less than 24dBA of noise.
I want to reduce the noise from my fan a
bit further.
The Zalman CMSP7000 is attractive and
cheap and quiet, but my CPU sits only two
inches below my power supply.
The fan on my CPU has three wires.
1. +5v
2. +12v
3. gnd
My question...
If I add a resistor in series with the +12v line,
would that reduce the fan speed?
Anybody know for certain?
Tnx,
Charles
G
Guest
Guest
Often, the fan does not need to run at full speed. If you board support fan
speed control, you can use http://www.almico.com/speedfan.php. If your board
is an MSI, you can use PC Alert 4 that reduces significantly the processor
heat. It calls the HALT processor instruction that reduces power
consumption. While you don't use CPU intensive application, the processor
will stay cool, which is the case in email and Internet browsing. As for the
resistor, I suggest using a variable resistor since it is not obvious to
know for a specific resistor which speed the fan will run.
Sylvain.
"Charles" <charles97@dunjas.com> wrote in message
news:423F27D4.63D087BD@dunjas.com...
> bit further.
> 1. +5v
> 2. +12v
> 3. gnd
> My question...
> Tnx,
> Charles
G
Guest
Guest
> 1. +5v
> 2. +12v
> 3. gnd
It has 3 wires, but it doesn't have +5v. The third wire is for the fan
speed.
> My question...
> If I add a resistor in series with the +12v line, would that reduce the
> fan speed?
Yes.
Yes.
Abit KT7-Raid (KT133) Tbred B core CPU @2400MHz (24x100FSB)
My server http://wesnewell.no-ip.com/cpu.php
Verizon server http://mysite.verizon.net/res0exft/cpu.htm
Charles
341
> Yes.
Wes,
Can you guess the milliampere range.
If I know the approximate milliamperes,
I could guess a starting value for a resistor.
umm... I suppose. If I am going to cut wires anyway,
I should just put a milliamp meter in the circuit.
(but I sometimes display the indications of laziness)
Charles
OBTW: I pulled the CPU fan connector one day
to see if got warm. It took about 20 minutes for it
to become warm to the touch.
G
Guest
Guest
> Wes,
Should be on the fan.
Ed Light
Smiley :-/
MS Smiley :-\
Send spam to the FTC at
uce@ftc.gov
Thanks, robots.
Dave
2,727
news:423F8EFA.B3DF392D@dunjas.com...
>> Yes.
> Wes,
> Charles
Or you could buy a rotary switch and some 1 amp diodes and use it to make a
controller. I made one using 8 diodes and a 12 position rotary switch. The
diodes were soldered in series to the output points on the switch and one
end was hooked up to the 12V rail and the other to the fan. By rotating the
switch, more diodes were added to the load and the voltage to the fan
dropped as each of the diodes has about 0.75V drop.
Diode switch output
0 0 0 0 0
| rotary switch outer
poles
rotary switch centre pole
The above diagram should help. Imagine the line with the diodes is
circular. I hooked it up with a wire from the centre pole of the rotary
switch to the fan and the power wire to one end of the diode bus, depending
if you cut the 12volt wire or the 0volt wire and insert it. If it doesn't
work with the input wire on one end, attach it to the other. I've only
shown 4 diodes but you can add more.
I used a Molex y-adapter power cable and cut either the 12V (yellow) or the
0V (black) wire (can't remember and am to lazy to work it out).
It cost less than $5.00 all up.
Dave
Charles
341
> controller.
Dave,
I like it.
Tnx,
Charles
rms
463
Directron.com sells an inline adjustable fanspeed controller by Zalman for
$4. Just get that, it works great.
rms
G
Guest
Guest
They also have one you can put in an empty pci cutout -- so you can
adjust the volume externally via the back of the computer. If you want
to plug it into a three pin, you'll have to get 4 to 3 pin converters,
and so on, but it's a mighty spiffy solution if you don't mind the extra
money -- prolly run around 40 or 50 bucks all said and done.
Bryan
> rms
Charles
341
> rms
rms,
Cool alias. I once worked next to Robert L. Carrol.
I found the Zalman at Fry's.
I got DOUBLE lucky.
They had it on sale for $3.90 !!!
Anyway, I will try it.
Plus...
One more thing...
Most of the fans that have current listed on the box
fall in the range between .1 amp and .15 amp.
Tnx,
charles
Charles
341
> bit further.
> 1. +5v
> 2. +12v
> 3. gnd
> My question...
> Tnx,
> Charles
I stuck a pencil in each of the cpu and power supply fans.
Guess where the major noise is coming from?
The hard drive.
All this time I thought it was the fans.
Now I have to find a way to quiet the hard drive.
Thanks to everybody for their suggestions.
Charles
G
Guest
Guest
A variable resistor (or a rheostat) is all that the Thermaltake fans
use... that might be an idea... but you'll want to monitor your system
temp as you trade off fan speed for silence... is that Cooler Master X
Dream II a copper or aluminum heat sink?
I've got a Zalman 7000Cu on my PVR machine @ home and I love it... but I
also have a Thermaltake Silent Boost ($30 Cdn, or about $20-25 US
probably) on my regular tower... being a full copper heat sink it
doesn't need as much of a fan to dissipate the heat; the copper does a
much better job than aluminum....
anyways, hope you find a solution!
jb
> Sylvain.
>>bit further.
>>1. +5v
>>2. +12v
>>3. gnd
>>My question...
>>Tnx,
>>Charles
G
Guest
Guest
If you're serious about silencing your hard drives I'd recommend the
SilenX Luxurae HD Silencing System. Reviews @
http://www.auphanonline.com/articles/view.php?article_id=1471
http://www.overclockers.com/articles1177/
SilenX's website (where you can order it direct from them if you can't
find it locally):
http://www.silenxusa.com/productcart/pc/configureprd_z.asp?idcategory=17&idproduct=46
It's $39.95 US, plus another $13.95 if you buy their silent fan add-on
(SilenX's silent fans are truly silent too; very sweet). Well worth the
price though IMHO if you want a silent system...
For a cheaper solution you could probably also check out this site:
http://www.endpcnoise.com/cgi-bin/e/scan/st=db/co=yes/rf=%2A/fi=products/sf=category/op=eq/se=Hard%20Drive%20Enclosures.html
The Nexus vibration dampeners might help... only $19.95 US, but I doubt
they'd do anything nearly close to what the silenx hdss does...
Anyways, good luck in the quest for silence... I've found that the more
I spend trying to silence things, the lower my tolerance gets for any
noise... doubt I'll ever be happy ;-)
JB
>>bit further.
>>1. +5v
>>2. +12v
>>3. gnd
>>My question...
>>Tnx,
>>Charles
> The hard drive.
> Charles
