Hello.
I have been having this problem for quite some time. I just recently installed a clean install of Windows 7 Ultimate 64bit and there were no problems in the installation. A problem occurs every time i launch a game, for example Fallout 3, Counter-strike 1.6. I'm not sure what it is, but i had Windows XP before Windows 7 and then Counter-strike 1.6 always crashed into Blue Screen and i went with my computer for a repair and they told me the memory was bad, so i bought a new memory, but i am still having these problems. I recently used Windows memory diagnostic and the results were that their was a hardware failure, could there be something in the computer damaging those RAM's? And if so what could it be - i'm always guessing if the video card, power supply, processor is the problem? Is there some kind of a program that can check this stuff out?
AMD Athlon 64 X2 Dual Core Processor 6400+ (Black Edition)
Sparkle Nvidia Geforce 8800 GT
Mushkin 2x2GB XP2-8500 (2.0-2.1V 5-5-5-15)
Gigabyte MA-GA770-DS3
500w Power Supply
I checked the Event Viewer and found this Kernel-Power 41 (63) Critical Error for every time this Blue screen happens. The log says this:
- <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
- <System>
<Provider Name="Microsoft-Windows-Kernel-Power" Guid="{331C3B3A-2005-44C2-AC5E-77220C37D6B4}" />
<EventID>41</EventID>
<Version>2</Version>
<Level>1</Level>
<Task>63</Task>
<Opcode>0</Opcode>
<Keywords>0x8000000000000002</Keywords>
<TimeCreated SystemTime="2011-02-19T00:51:47.286011800Z" />
<EventRecordID>9295</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="8" />
<Channel>System</Channel>
<Computer>Arnar-PC</Computer>
<Security UserID="S-1-5-18" />
</System>
- <EventData>
<Data Name="BugcheckCode">24</Data>
<Data Name="BugcheckParameter1">0x0</Data>
<Data Name="BugcheckParameter2">0xfffff8800ae18a70</Data>
<Data Name="BugcheckParameter3">0x2</Data>
<Data Name="BugcheckParameter4">0xffffffffffffffff</Data>
<Data Name="SleepInProgress">false</Data>
<Data Name="PowerButtonTimestamp">0</Data>
</EventData>
</Event>
500w Power Supply
- <System>
<Level>1</Level>
<Task>63</Task>
<Opcode>0</Opcode>
<Correlation />
</System>
- <EventData>
</EventData>
</Event>
