Archived from groups: alt.comp.hardware.overclocking.amd (More info?)
I've messed around with bios a few times and I've been unsuccessful
Overclocking my CPU...Would anyone have any suggestions for me...I've tried
tampering with fsb and voltage, just fsb, ram timings, but i haven't had any
luck coming up with the right settings...Now i'm not a computer guru or
anything and that's probably have the reason but I was hoping to OC this
chip. Oh, and i've tried Ntune and that hasn't worked as well.
Even if someone with a very similar system to let me know what they have for
bios settings to help??
Tnx in advance
Operating System Microsoft Windows XP Professional
OS Service Pack Service Pack 2
Motherboard
BIOS Type Award (11/12/04)
Communication Port Communications Port (COM1)
Communication Port Communications Port (COM2)
Communication Port ECP Printer Port (LPT1)
CPU Type AMD Athlon XP-A, 1833 MHz (11 x 167) 2500+
Motherboard Chipset nVIDIA nForce2 Ultra 400
Motherboard Name Asus A7N8X-E Deluxe (5 PCI, 1 AGP Pro, 1 WiFi, 3 DDR DIMM,
Audio, Gigabit LAN)
System Memory 512 MB PC 4000 GEIL (DDR SDRAM)
Display
Video Adapter RADEON 9800 PRO - Secondary (128 MB)
Video Adapter RADEON 9800 PRO (128 MB)
3D Accelerator ATI Radeon 9800 Pro (R350)
Monitor Plug and Play Monitor [NoDB] (CX 026340)
All you should need to do is to raise the FSB and the voltage depending on
how much you want to overclock. A reasonable speed would be 2200MHz
(11x200), basically a 3200+ speed. I'd start by raising vcore to 1.85v and
FSB to 200. If it boots there, start lowering vcore til it won't work.
Hopefully you have a decent cooler (not stock). Use a boot cd or floppy
when testing so you won't corrupt the HD.
I was able to oc after...not 3200 speeds tho but i got a significant jump at
1980 mhz. Tnx for your help.
"Wes Newell" <w.newell@TAKEOUTverizon.net> wrote in message
newsan.2005.05.18.17.57.27.304379@TAKEOUTverizon.net...
>> tried
>> any
>> for
>> DIMM,
> Abit KT7-Raid (KT133) Tbred B core CPU @2400MHz (24x100FSB)
> My server http://wesnewell.no-ip.com/cpu.php > Verizon server http://mysite.verizon.net/res0exft/cpu.htm >
