G
Guest
Guest
Archived from groups: alt.comp.hardware.overclocking.amd (More info?)
When setting a TV as a Second display device will i get componet as a
connection option ???
Ive got a Nvidia 6600 GT With a Toshiba Toshiba 86cm 36SW9UA (HD)
Just had a look at the
71.89_ForceWare_Release_70_Graphics_Display_Property_Users_Guide. And
it seems not to have the option. It has Svideo,Composite or DVI. This
is weird as my card came with a DIN to Componet connector. Which would
asume i would use to connect to a TV right ?
So what would i select DVI or is it just not showing componet for some
reason ?
Thanks this has scared me. I can connect via Svideo but NO HD Tv for
me then. And the TV dont have DVI
What kidn of quality do you get with your TV out connectionand how
much trouble was it to setup to get a good picture and is HD good on
yours.
Thanks all.
Thanks DAVE.
reason ?
yours.
Thanks all.
Thanks DAVE.
