G
Guest
Guest
Archived from groups: alt.comp.hardware.overclocking.amd (More info?)
I have just got an XP2000+ along with a Abit KD7 raid mobo and the
temperatures are rather alarming, Motherboard Monitor is quoting
temperatures of a case temp of 47 and CPU idle temps of ~50c and under
load temps of 95c. Current drivers for everything are installed.
The Bios quotes a surface temperature 65 and a core temp of 85 after
resetting after full load.
This is using a copper heatpipe Coolermaster heatsink which has
previously been used on a Duron 1600 and a Athlon XP2500+ Barton on a
Abit KT7a & MSI K7N2 Delta with a pretty much constant 60C even when
the 2500 was overclocked to 3200.
Other coolers have been used with the same result, and the spread of
the HS compound when the HSF was removed indicates a good contact
between CPU and HSF.
System:
Windows XP Pro
Athlon XP 2000+
Abit KD7-RAID mobo
512meg RAM, PC2100
Radeon 7200 DDR VIVO
4x40gig HDs
CD-RW & DVD-RW
CPU details are:
AX2000 DMT3C
AGIA 0230WPHW
91545930695
ButIstillneedtoknowwhat'sinthere!Thekeytoanysecurity
systemishowit'sdesigned!Thatdependsonwhyitwasdesigned!
Ihavetoknowwhatwhoeverdesigneditwastryingtoprotect!
(Blakes 7, City on the Edge of the World - Vila in typical panic mode)
System:
Windows XP Pro
Athlon XP 2000+
Abit KD7-RAID mobo
512meg RAM, PC2100
4x40gig HDs
CD-RW & DVD-RW
CPU details are:
AX2000 DMT3C
AGIA 0230WPHW
91545930695
