Tom's Hardware > Forum > Overclocking > AMD > Calculating CFM with a variable speed fan
Forum Overclocking : AMD - Calculating CFM with a variable speed fan
Archived from groups: alt.comp.hardware.overclocking.amd (More info?)
is CFM linear? for instance if a 5000 rpm 80CFM fan is run at 2500rpm will
the CFM be 40CFM?
Sponsored Links
> will the CFM be 40CFM?
Approximately, yes. The approximation getting better as the pressure
difference across the fan goes to zero (with a perfect theoretical fan being
exactly linear).
Michael Brown
www.emboss.co.nz : OOS/RSI software and more :)
Add michael@ to emboss.co.nz ---+--- My inbox is always open
Reply to Anonymous
> the CFM be 40CFM?
If I remember the physics properly (it has been a couple of decades) a
perfect fan will have air flow linear with rotational speed. Rotational
speed is wildly nonlinear with the voltage applied.
John McGaw
[Knoxville, TN, USA]
http://johnmcgaw.com
Reply to Anonymous
There are 1150 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 vianescute won the Freshman badge
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
