Tom's Hardware > Forum > Overclocking > General Discussions > Help with Memory issues
Archived from groups: alt.comp.hardware.homebuilt,alt.comp.hardware.overclocking (More info?)
Folks,
I seem to have developed a problem with the system's memory and was hoping
someone may be able to offer some advice.
The system was:
Abit AT7-Max-2
Athlon XP2000
1Gb of Ram consisting of 1x 256Mb Kingtson ValueRam (266), 1x256Mb Aria
Generic DDR266 & 1x 512Mb Crucial DDR400 (Double Sided)
XP Pro Fully patched
This little setup all worked very nicely with the BIOS reporting that it had
stepped down the speed to the lowest common denominator of 266.
I have replaced the XP2000 with and XP2500 and the 2x 256Mb sticks have been
replaced with a single 512Mb DDR333 (Single Sided) from Aria. This is where
the problem starts.
When I try to run the system with the two 512Mb sticks the system stops at
the ESCD update stage.... just hangs.
If I take out the Aria 512 and leave in the Crucial 512... same problem
If I take out the Crucial 512 and leave in the Aria 512 It works!
If I put in the Crucial 512 and the Aria 256, it hangs
If I put in the Aria 512 and the Aria 256... it hangs!
I now take the Crucial 512 and stick it in another machine and it works
perfectly. huh?
Right now I'm able to run the system with just the new Aria 512 stick....
Very frustrating!
Any suggestions gratefully received!
Cheers!
Rez Manzoori
Sponsored Links
> Very frustrating!
Maybe your memory timings are being recognised incorrectly? Can you set
them manually in your BIOS to their slowest settings and see if it boots
then?
Stoneskin
[Insert sig text here]
Reply to Anonymous
Hi Stoneskin,
I'll be honest I have been randomly tinkering with the settings in the vain
hope that something will work. Here are the settings as they work with the
ARIA 512Mb stick:-
DRAM timing selectable - By Spd
Cas Latency Time - 2.5 - (1.5, 2, 3)
Bank Interleave - Disabled (2 bank, 4Bank)
Precharge to active (Trp) - 3T (2T)
Active to Precharge (Tras) - 7T (6T)
Active to Cmd (trcd) - 3T (2T)
DRAM Burst Length - 4 (8)
DRAM Queue Depth - 4 Level (2 Level, 3 Level)
DQS Drive strength - Auto (Low, Medium, High)
DDR DQS Inout Delay - Auto (Manual)
DDR DQS Output Delay - Auto (Manual)
MD Drive Strength - Auto (Manual)
DIMM 1-4 CMD drive control - Auto (Manual)
DRAM Access - 3T (2T)
Enhance DRAM performance - Disabled (enabled)
DRAM command rate - 2T Command (1T Command)
Write recovery Time - 3T (2T)
DRAM tWTR - 3T (1T)
DCLK Output Delay - 0ps
Sadly I have no idea what any of these really mean!
Rez Manzoori
"Stoneskin" <no@thanks.com> wrote in message
news:MPG.1ad7839efd22e29c989759@news.individual.net...
stick....
> > Very frustrating!
> then?
> Stoneskin
Reply to Anonymous
You are always better off NOT mixing brands of RAM in system's if possible,
as you have found out.
DaveW
"Rez Manzoori" <Rez.Manzoori@Mykeks.ntlworld.Com> wrote in message
news:Ecebc.45$984.17@newsfe1-win...
> Folks,
> The system was:
> Abit AT7-Max-2
> Athlon XP2000
had
been
where
> the problem starts.
> perfectly. huh?
> Very frustrating!
> Cheers!
> Rez Manzoori
Reply to Anonymous
> Hi Stoneskin,
> ARIA 512Mb stick:-
> DRAM tWTR - 3T (1T)
I'm not 100% sure myself but try manually changing the memory to it's
slowest, i.e. most compatible settings. CAS up to 3.0 for a start.
I've no idea if this will help the compatibility between the modules but
that's where I'd start anyway. Sorry I couldn't be much help :0/
Stoneskin
Reply to Anonymous
There are 1025 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
